Will this piston/stroke/rod length work? #235521
02/25/09 12:41 AM
02/25/09 12:41 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Mathematically this should work, but will the rod length be ok and not pull too much of the piston ABDC?
4.375 stroke
6.9 rod
1.621 comp height
10.725 deck height
What do you think?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Will this piston/stroke/rod length work? [Re: Von] #235522
02/25/09 01:31 AM
02/25/09 01:31 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
That will depend on the diameter of the crank counterweights and the contour of the piston skirts and thickness at the wristpin.
To the Deck the math is fine. So is my quick math to BDC. with a 7.25" crank. If things get close get the Makita, out. mike
Re: Will this piston/stroke/rod length work? [Re: Sport440] #235523
02/25/09 12:39 PM
02/25/09 12:39 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Mike,
Thanks for your reply. If I do have clearance issues, can I turn the counterweights down and rebalance?
Seems like this combo uses 7.1 rods usually, but I already have the pistons and started
Re: Will this piston/stroke/rod length work? [Re: Von] #235524
02/25/09 12:54 PM
02/25/09 12:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Mike,
One thing you need to be concerned about is how far the pistons pulls out the bottom of the bore with the shorter rod .
Re: Will this piston/stroke/rod length work? [Re: JohnRR] #235525
02/25/09 01:09 PM
02/25/09 01:09 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I run a 4.3 stroke with a 6.7 rod. If that helps
Re: Will this piston/stroke/rod length work? [Re: B1MAXX] #235526
02/25/09 01:13 PM
02/25/09 01:13 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Do you know what the diameter is of your counterweights?
Re: Will this piston/stroke/rod length work? [Re: Von] #235527
02/25/09 01:14 PM
02/25/09 01:14 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Not off the top of my head but it is an out of the box Ohio crank.
Re: Will this piston/stroke/rod length work? [Re: B1MAXX] #235528
02/25/09 01:16 PM
02/25/09 01:16 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Thanks!! I'll look it up.
Re: Will this piston/stroke/rod length work? [Re: Von] #235529
02/25/09 01:21 PM
02/25/09 01:21 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Just mock it up. You can't make mistakes that way.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Will this piston/stroke/rod length work? [Re: B1MAXX] #235530
02/25/09 01:35 PM
02/25/09 01:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
B or RB ???
Re: Will this piston/stroke/rod length work? [Re: Von] #235531
02/25/09 01:43 PM
02/25/09 01:43 PM
AndyF Offline
AndyF  Offline
You'll be fine, where did you find a 6.90 long rod? The popular rods are 6.70, 6.80 and 7.10. I've seen a couple of other lengths but never 6.90.
Re: Will this piston/stroke/rod length work? [Re: AndyF] #235532
02/25/09 01:45 PM
02/25/09 01:45 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
I was thinking I had seen a 6.9. But, I went back and looked and I was wrong. Back to the figuring.
What about 4.5 stroke with a 6.8 rod? It figures to be .054 down in the hole. Will that combo pull too much out at BDC?
Re: Will this piston/stroke/rod length work? [Re: JohnRR] #235533
02/25/09 11:03 PM
02/25/09 11:03 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
B or RB ???
rb
Re: Will this piston/stroke/rod length work? [Re: Von] #235534
02/25/09 11:27 PM
02/25/09 11:27 PM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
http://store.summitracing.com/partdetail.asp?part=ESP%2D6860C3D&autoview=sku
how about a 6.86 hemi rod will leave ya about .056 in the hole
Re: Will this piston/stroke/rod length work? [Re: n_bogie1984] #235535
02/25/09 11:40 PM
02/25/09 11:40 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
I checked and the compression height is 1.633
So would 4.5 stroke, 6.8 rod, work? I come with .042 in the hole.
Would it be ok with a 7.48 counter weight? What about bdc?
Re: Will this piston/stroke/rod length work? [Re: n_bogie1984] #235536
02/25/09 11:41 PM
02/25/09 11:41 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Good idea 'cept I need a bbc width rod.
Re: Will this piston/stroke/rod length work? [Re: Von] #235537
02/25/09 11:51 PM
02/25/09 11:51 PM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
well you cant exspect me to get everything right
Re: Will this piston/stroke/rod length work? [Re: Von] #235538
02/25/09 11:55 PM
02/25/09 11:55 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Why, are you using a bbc crank?
Re: Will this piston/stroke/rod length work? [Re: RemCharger] #235539
02/26/09 10:06 AM
02/26/09 10:06 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
[quoteWhy, are you using a bbc crank?
Some if not most of the aftermarket cranks are set up for a BBC rod.
Re: Will this piston/stroke/rod length work? [Re: Von] #235540
02/26/09 01:14 PM
02/26/09 01:14 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Why not just use 7.1 rod 1.313 piston (3.75 stroke 400 shelf piston) and 4.5 stroke rb and deck the block for desired comp ratio?
