Page 1 of 3 1 2 3
6.4 BGE specs #2355042
08/16/17 07:56 PM
08/16/17 07:56 PM
Canada
WO23Coronet Offline OP
Canada
I know that they use the Hellcat block and heads, but what about the rotating assembly? I'm guessing that they have a forged crank and forged powder metal rods, but are the pistons forged? I've heard that they are but haven't been able to confirm. Also, what are the cam specs? Likely using a 5.7 cam?
Re: 6.4 BGE specs [Re: WO23Coronet] #2355086
08/16/17 09:07 PM
08/16/17 09:07 PM
Australia
L4staero Offline
L4staero  Offline
Australia
Dodge says the pistons are forged however all the Hemi vendors say they are not
Re: 6.4 BGE specs [Re: WO23Coronet] #2355155
08/16/17 11:12 PM
08/16/17 11:12 PM
USA
hudsonhornet7x Offline
USA
The BGE block is the same as Hellcat but painted a different color.
The crank is a forged crank that is the SAME as the srt forged 6.4 crank from the passenger car. This was confirmed by a Hemi vendor.
I would treat the BGE just like a srt rotating assembly- great crank but rods and pistons are not suitable for a serious performance build.
Re: 6.4 BGE specs [Re: WO23Coronet] #2355271
08/17/17 03:19 AM
08/17/17 03:19 AM
Canada
Canada
Ah well, I thought maybe the BGE 6.4 would be a decent boost ready junkyard engine if it had forged slugs from the factory
Re: 6.4 BGE specs [Re: WO23Coronet] #2355293
08/17/17 06:50 AM
08/17/17 06:50 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Heads are not hellcat, Hellcat have larger intake mounting area.
6.4 Short block will take some boost just make sure you open up the top ring gap. granted your not going to hunt down any 405 street outlaws with a stock BGE 6.4
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 6.4 BGE specs [Re: WO23Coronet] #2355331
08/17/17 10:20 AM
08/17/17 10:20 AM
Australia
L4staero Offline
L4staero  Offline
Australia
I have a BGE on its way to me so i will keep u updated. I think its in the hemi vendors best interest to not let on that the pistons and rods are any good. Their livelyhood is selling pistons and rods always with the scare tactics of no more than 5 psi boost on 6.4s etc. Or you need pistons and rods to make power.....Quite a few cars locally on standard pistons. Low 10s in a 300 with a 6.4.
Heads are cast same as a hellcat... same material andnports just intake bolt pattern differs
Re: 6.4 BGE specs [Re: ric3xrt] #2355645
08/17/17 08:27 PM
08/17/17 08:27 PM
Canada
Canada
Same casting (ports, material, heat treating, reinforcements etc), but different bolt pattern.
Re: 6.4 BGE specs [Re: L4staero] #2355646
08/17/17 08:28 PM
08/17/17 08:28 PM
Canada
Canada
Sweet! Are you going to tear into abit or run as is?
Re: 6.4 BGE specs [Re: WO23Coronet] #2355739
08/17/17 10:26 PM
08/17/17 10:26 PM
Australia
L4staero Offline
L4staero  Offline
Australia
Will be doing a full tear down
Re: 6.4 BGE specs [Re: WO23Coronet] #2355768
08/17/17 11:01 PM
08/17/17 11:01 PM
Australia
L4staero Offline
L4staero  Offline
Australia
Originally the crank was a different part number to the srt 6.4 but now i think they are the same. I should have both an srt and a 2014 (1st year) bge pulled down side by side to compare cranks, rods and pistons
Re: 6.4 BGE specs [Re: WO23Coronet] #2356408
08/19/17 04:48 AM
08/19/17 04:48 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
Does anyone know the separate part numbers for the BGE block, heads and short block?
Thank you!
Wailin
Re: 6.4 BGE specs [Re: WO23Coronet] #2356456
08/19/17 10:13 AM
08/19/17 10:13 AM
Australia
L4staero Offline
L4staero  Offline
Australia
68280506AA $810 BGE head 6.4 right
68280507AA $865 BGE head 6.4 left
68226133AA Short Block $2,938.00
Block-Engine Cylinder 68166434AD$1,429.45
Re: 6.4 BGE specs [Re: WO23Coronet] #2356929
08/20/17 02:05 AM
08/20/17 02:05 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
Outstanding! Thank you very much! Do you have a seller that you recommend?
Re: 6.4 BGE specs [Re: WO23Coronet] #2356960
08/20/17 03:46 AM
08/20/17 03:46 AM
Australia
L4staero Offline
L4staero  Offline
Australia
A seller for new or used engines?
For new stuff i always recommend Andy at Eastcoastmoparts.com
The seller is bought my used BGE from was horrible to deal with however the engine was $1000 less than every other seller.
Re: 6.4 BGE specs [Re: WO23Coronet] #2357438
08/21/17 04:26 AM
08/21/17 04:26 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
Thank you! I was thinking new.
Re: 6.4 BGE specs [Re: L4staero] #2371176
09/15/17 12:31 PM
09/15/17 12:31 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
drinking
Re: 6.4 BGE specs [Re: WO23Coronet] #2371527
09/16/17 12:25 AM
09/16/17 12:25 AM
Australia
L4staero Offline
L4staero  Offline
Australia
When i say BGE are cast same as hellcat i dont mean that they are the same casting just with different intake face drillings they are not.
However they share the same casting strength improvments but the bge has no allowances cast into it for a hc intake pattern
Re: 6.4 BGE specs [Re: WO23Coronet] #2371640
09/16/17 10:50 AM
09/16/17 10:50 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
IF you get the chance to cut both heads open, the Hellcat have more material under the Intake valve seat and waters passages around exhaust port are larger.
Re: 6.4 BGE specs [Re: ric3xrt] #2371748
09/16/17 03:47 PM
09/16/17 03:47 PM
Canada
Canada
Over the BGE head?
Re: 6.4 BGE specs [Re: WO23Coronet] #2372729
09/18/17 02:26 PM
09/18/17 02:26 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
The BGE has a different part # stamped in the top of the piston but can not come up with anything on the #. I bet it has forged pistons!!!
Page 1 of 3 1 2 3
