Page 1 of 3 1 2 3 >
#2355042 - 08/16/17 05:56 PM 6.4 BGE specs
WO23Coronet Offline
Loc: Canada
I know that they use the Hellcat block and heads, but what about the rotating assembly? I'm guessing that they have a forged crank and forged powder metal rods, but are the pistons forged? I've heard that they are but haven't been able to confirm. Also, what are the cam specs? Likely using a 5.7 cam?
#2355086 - 08/16/17 07:07 PM Re: 6.4 BGE specs [Re: WO23Coronet]
L4staero Offline
Loc: Australia
Dodge says the pistons are forged however all the Hemi vendors say they are not
#2355155 - 08/16/17 09:12 PM Re: 6.4 BGE specs [Re: WO23Coronet]
hudsonhornet7x Offline
Loc: Plumer, Pa
The BGE block is the same as Hellcat but painted a different color.
The crank is a forged crank that is the SAME as the srt forged 6.4 crank from the passenger car. This was confirmed by a Hemi vendor.
I would treat the BGE just like a srt rotating assembly- great crank but rods and pistons are not suitable for a serious performance build.
XP29H8B198192
#2355271 - 08/17/17 01:19 AM Re: 6.4 BGE specs [Re: WO23Coronet]
WO23Coronet Offline
Loc: Canada
Ah well, I thought maybe the BGE 6.4 would be a decent boost ready junkyard engine if it had forged slugs from the factory
#2355293 - 08/17/17 04:50 AM Re: 6.4 BGE specs [Re: WO23Coronet]
ric3xrt Offline
Loc: Trumbauersville PA
Heads are not hellcat, Hellcat have larger intake mounting area.
6.4 Short block will take some boost just make sure you open up the top ring gap. granted your not going to hunt down any 405 street outlaws with a stock BGE 6.4
Truth has no agenda, but those with an agenda don't always acknowledge truth
74 D100 D-Code,3x75 D100 D-code, 3x77 D100 D-code,6x78 D150 D-D-code...lots of pre 81 trucks
75 4x2 Ramcharger....G3 coming soon
2003 Ram st
2004 Rumble Bee
2004 Ram GTX(Plum Crazy)
2005 Ram GTXtreme(s Plum Crazy,Banana Yellow)
Any info on these trucks is greatly appreciated
2005 Ram 1500 (drag truck in building)
2014 1500 tradesman(shhhh, it's hiding a 7.0 short block under those eagle heads.
#2355331 - 08/17/17 08:20 AM Re: 6.4 BGE specs [Re: WO23Coronet]
L4staero Offline
Loc: Australia
I have a BGE on its way to me so i will keep u updated. I think its in the hemi vendors best interest to not let on that the pistons and rods are any good. Their livelyhood is selling pistons and rods always with the scare tactics of no more than 5 psi boost on 6.4s etc. Or you need pistons and rods to make power.....Quite a few cars locally on standard pistons. Low 10s in a 300 with a 6.4.
Heads are cast same as a hellcat... same material andnports just intake bolt pattern differs
Edited by L4staero (08/17/17 08:21 AM)
#2355645 - 08/17/17 06:27 PM Re: 6.4 BGE specs [Re: ric3xrt]
WO23Coronet Offline
Loc: Canada
Same casting (ports, material, heat treating, reinforcements etc), but different bolt pattern.
#2355646 - 08/17/17 06:28 PM Re: 6.4 BGE specs [Re: L4staero]
WO23Coronet Offline
Loc: Canada
Sweet! Are you going to tear into abit or run as is?
#2355739 - 08/17/17 08:26 PM Re: 6.4 BGE specs [Re: WO23Coronet]
L4staero Offline
Loc: Australia
Will be doing a full tear down
#2355768 - 08/17/17 09:01 PM Re: 6.4 BGE specs [Re: WO23Coronet]
L4staero Offline
Loc: Australia
Originally the crank was a different part number to the srt 6.4 but now i think they are the same. I should have both an srt and a 2014 (1st year) bge pulled down side by side to compare cranks, rods and pistons
#2356408 - 08/19/17 02:48 AM Re: 6.4 BGE specs [Re: WO23Coronet]
Wailin D Offline
Loc: Southern Missouri
Does anyone know the separate part numbers for the BGE block, heads and short block?
Thank you!
Wailin
#2356456 - 08/19/17 08:13 AM Re: 6.4 BGE specs [Re: WO23Coronet]
L4staero Offline
Loc: Australia
68280506AA $810 BGE head 6.4 right
68280507AA $865 BGE head 6.4 left
68226133AA Short Block $2,938.00
Block-Engine Cylinder 68166434AD$1,429.45
#2356929 - 08/20/17 12:05 AM Re: 6.4 BGE specs [Re: WO23Coronet]
Wailin D Offline
Outstanding! Thank you very much! Do you have a seller that you recommend?
#2356960 - 08/20/17 01:46 AM Re: 6.4 BGE specs [Re: WO23Coronet]
L4staero Offline
Loc: Australia
A seller for new or used engines?
For new stuff i always recommend Andy at Eastcoastmoparts.com
The seller is bought my used BGE from was horrible to deal with however the engine was $1000 less than every other seller.
#2357438 - 08/21/17 02:26 AM Re: 6.4 BGE specs [Re: WO23Coronet]
Wailin D Offline
Thank you! I was thinking new.
#2371176 - 09/15/17 10:31 AM Re: 6.4 BGE specs [Re: L4staero]
ric3xrt Offline
drinking
2003 Ram st
2004 Rumble Bee
#2371527 - 09/15/17 10:25 PM Re: 6.4 BGE specs [Re: WO23Coronet]
L4staero Offline
Loc: Australia
When i say BGE are cast same as hellcat i dont mean that they are the same casting just with different intake face drillings they are not.
However they share the same casting strength improvments but the bge has no allowances cast into it for a hc intake pattern
#2371640 - 09/16/17 08:50 AM Re: 6.4 BGE specs [Re: WO23Coronet]
ric3xrt Offline
IF you get the chance to cut both heads open, the Hellcat have more material under the Intake valve seat and waters passages around exhaust port are larger.
#2371748 - 09/16/17 01:47 PM Re: 6.4 BGE specs [Re: ric3xrt]
WO23Coronet Offline
Loc: Canada
Over the BGE head?
#2372729 - 09/18/17 12:26 PM Re: 6.4 BGE specs [Re: WO23Coronet]
8secDart Offline
Loc: Salisbury North Carolina
The BGE has a different part # stamped in the top of the piston but can not come up with anything on the #. I bet it has forged pistons!!!
Page 1 of 3 1 2 3 >
25,346 Registered Members
190,219 Topics
CARBON FIBER HOOD
by A/MP
Today at 12:22 AM
TUNING W2 HEADS
by A/MP
Today at 12:15 AM
727 clutch pressure plate gap newb question
by radar
Today at 12:01 AM
Dakota clip- who has done and retained the EFI?
by CrAzYMoPaRGuY
Yesterday at 11:26 PM
