Re: Small Block Sidewinder Heads FULL port work pics
[Re: Prochargedmopar]
#2354404
08/15/17 06:56 PM
08/15/17 06:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Couple of questions... what intake will these use and what is the valve length on them.. I would like to pick up a set for .600-.650 lift.. most likely I will do my own port work.. also how does the push rod look in there.. can a 3/8 push rod be used
[Re: MR_P_BODY]
#2354518
08/15/17 11:08 PM
08/15/17 11:08 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
Mr. P, They have 1/2"' push rod holes if that helps at all.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#2354535
08/15/17 11:39 PM
08/15/17 11:39 PM
MR_P_BODY
Mr. P, They have 1/2"' push rod holes if that helps at all. Thanks on that part.. do you know the valve length for a .600-.650 valve for that head.. thanks for the help
[Re: MR_P_BODY]
#2354539
08/15/17 11:43 PM
08/15/17 11:43 PM
YO7_A66
Indiana
Todd set me up with a valve/spring setup for apx .625", but I do not have it with me right now. I will get back with you on the valve length tomorrow.
#2354633
08/16/17 02:32 AM
08/16/17 02:32 AM
Posts: 2,644 North Carolina
sasquatch
North Carolina
Hey The valves are 5.060 Long but you guys are confusing the heck out of me. I used a 924 comp spring and those are set up for a 525 lift hydraulic cam not 625. I used a Comp 10 degree retainer and lock as well. P body I would set them up with an Isky 8005A for most applications of a cam that size with a flat tappet solid. They setup at about 1.900 and you do not want to go making the spring pockets way bigger. Oh and yes the heads of photo fame will be shipping in the AM. Todd
[Re: MR_P_BODY]
#2354686
08/16/17 08:46 AM
08/16/17 08:46 AM
YO7_A66
Indiana
""I used a 924 comp spring and those are set up for a 525 lift hydraulic cam not 625."" Oops, I fat fingered my response from my Ipad. Thanks Todd!
#2354777
08/16/17 12:05 PM
08/16/17 12:05 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
ProCharged, How many inches are you building? 190CC of port volume seems small to support a stroker.
Yo7, If his fully ported came in at 190, where were yours?
Final price, assembled, ready to bolt on?
After every passing year, I like my Airwolf 220s more and more...
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#2354831
08/16/17 01:25 PM
08/16/17 01:25 PM
YO7_A66
Indiana
""Yo7, If his fully ported came in at 190, where were yours?"" I do not have the flow numbers on my heads,,, yet. I am patiently waiting for the numbers.
[Re: BradH]
#2354847
08/16/17 01:54 PM
08/16/17 01:54 PM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
Guess he likes to make 'em shiny, eh? I suppose it's OK to compare your heads to old "modern" SBC heads, but the next generation LS3 is already outdated compared to the LS7 stuff that's been out for years, too. Or maybe I've missed the point of your comparison... My thoughts are this. With bone stock factory LS heads I see guys making 750whp using the 78/75 turbo I recently purchased. I see a few making 1000hp with the 80mm+ turbos (big frame). So, If I can get some MOPAR heads that equal the potential of those and maintain about the same 3400# by offsetting the power adder weight with Aluminum heads I will be happy. I've got the $$ to run down to the junkyard and pick up a 5.3 but every time I get the urge something inside will not allow me to do it.. Paying 3-5x the price for the same power (heads and trans + machine work) doesn't make me the sharpest tool in the shed but it does keep my mopar a mopar.
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
[Re: MoparBilly]
#2354867
08/16/17 02:12 PM
08/16/17 02:12 PM
Prochargedmopar
Granbury TX
After every passing year, I like my Airwolf 220s more and more... 30 over 360 (366cu) I will be using a procharger that has 675hp potential. Then I will ADD the billet 78/75 turbo once I get the e85 carb dialed. Yes, I said add. Compound power adder. Yes I know it is redundancy. I like the sound of the blower but also like the top end potential and cool factor of the turbo along with being able to build some boost at stall. Pretty sure I will have more power potential than your N/A Airwolfs. Trouble is I think your the guy that was blowing up big blocks a decade or two ago with NOS so I would be looking at your rear end if we raced. I plan to cruise mine around the country to some roadkill events. It looks pretty rough. lol
[Re: MR_P_BODY]
#2354914
08/16/17 04:02 PM
08/16/17 04:02 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What I see is they flow 266.7 at .600 lift and thats where they peak If you look at my chart on the ProMaxx head you will see where I marked "high air speed". A head becomes a little turbulent and stalls shortly after that and backs up in flow. Usually because the air can't make the short turn. It skips across the bowl shutting off the good airflow across the top of the port. you can hear it happening at that point. If a head doesn't flow 200 plus cfm and .300 it isn't leaving my porting bench. -----Edelbrock--------------ProMaxx --------Intake-----------------intake .200-----128--------------------129 .300-----182--------------------184 .400-----215--------------------235 .450-----226--------------------251 .500-----233--------------------255-260 high air-speed .550-----236--------------------260 .600-----242--------------------264 .650-----243--------------------270 .700-----243--------------------263-270 .750----------------------------263-270
[Re: MR_P_BODY]
#2354952
08/16/17 04:58 PM
08/16/17 04:58 PM
Prochargedmopar
Granbury TX
Couple of questions... what intake will these use and what is the valve length on them.. I would like to pick up a set for .600-.650 lift.. most likely I will do my own port work.. also how does the push rod look in there.. can a 3/8 push rod be used Stock equipment will work. I have 2 available. A SP holley street dominator OR Edelbrock LD4B I'll check fitment of the latter and if things are too far out of wack Larry said he would port it for $300 I'll have to think about that though as I may be able to get a better designed intake for that price new. Still up in the air on this till I get the heads in hand.
#2354970
08/16/17 05:30 PM
08/16/17 05:30 PM
Prochargedmopar
Granbury TX
Man of many talents it appears. Larry is moving on..... lol
Not enough mopar guys to make a living. hahaha
