cyl ring spacers, where to get em #2352697
08/12/17 01:40 AM
08/12/17 01:40 AM
RapidRobert Offline OP
I have some pistons with std 3/16 top/2nd ring grooves & I have some 1/16 rings. I believe there are spacers to allow them to be used. Who sells em & do they work OK? thank you for your time.
Re: cyl ring spacers, where to get em [Re: RapidRobert] #2352812
08/12/17 01:05 PM
08/12/17 01:05 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Robert if IRC they were called GI spacers.Had a set installed on a 361 I had years ago.Machine shop had them.Ran that engine for like 3 years with no problems.Pulled it to put in a 440.Rocky
Chrysler Firepower
Re: cyl ring spacers, where to get em [Re: therocks] #2352823
08/12/17 01:19 PM
08/12/17 01:19 PM
I Googled GI spacers & some ring mfr's came up so I will go after some of them. thank you!
Re: cyl ring spacers, where to get em [Re: RapidRobert] #2352850
08/12/17 02:32 PM
08/12/17 02:32 PM
How much are the spacers compared to the correct ring set? confused
BTW, are those rings grooves for 5/64 rings or 3/16? confused
Re: cyl ring spacers, where to get em [Re: RapidRobert] #2352882
08/12/17 04:25 PM
08/12/17 04:25 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mine at the time was because the lands were too big.It was cheaper than pistons.IIRC all the machine work they did plus the spacers was like 50 bucks.Rocky
Chrysler Firepower
Re: cyl ring spacers, where to get em [Re: therocks] #2352888
08/12/17 04:39 PM
08/12/17 04:39 PM
I did knot know they required machine work. if so (for my app) then I should continue to try to sell my 1/16 rings & get a set of regular 5/64 rings (30 over 440 daily driver)
Re: cyl ring spacers, where to get em [Re: RapidRobert] #2352899
08/12/17 05:13 PM
08/12/17 05:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Machine work depends on whether you're just using the GL spacers to reduce the groove size for standard width rings or using them to repair worn grooves.
Re: cyl ring spacers, where to get em [Re: RapidRobert] #2352926
08/12/17 06:19 PM
08/12/17 06:19 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
you can buy a complete set of rings that reduces the rings from 5/64 to 1/16 ...
http://www.totalseal.com/rings-advantage-rings.html
http://www.enginelabs.com/news/total-seals-spacers-bring-thin-ring-technology-to-wide-grooves/
they aint cheap...lol
Tony
70 AARCuda Vitamin C
Re: cyl ring spacers, where to get em [Re: 70AARcuda] #2353770
08/14/17 05:56 PM
08/14/17 05:56 PM
I just got off the ph with Total Seal & the salesman said that they do not offer a spacer for 5/64 down to 1/16 & that he is not aware of any one else in the industry that does... Man I'd sure think that'd be a common (desired) item. I'd sure hate to think he (Ed) was lying just to possibly drum up a sale.
Re: cyl ring spacers, where to get em [Re: RapidRobert] #2353782
08/14/17 06:10 PM
08/14/17 06:10 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
You're talking about a .015625" spacer.
Doesn't seem like that would be super durable.
Re: cyl ring spacers, where to get em [Re: fast68plymouth] #2353886
08/14/17 09:21 PM
08/14/17 09:21 PM
Yes they (total seal) have .030" and .046" spacers for 2 rings that are even thinner than 1/16".
Re: cyl ring spacers, where to get em [Re: fast68plymouth] #2354669
08/16/17 05:55 AM
08/16/17 05:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I was thinking its very thin as 1/16 is 4/64 so the spacer would be 1/64 which is what Dwayne posted. Ron
Re: cyl ring spacers, where to get em [Re: RapidRobert] #2354671
08/16/17 06:10 AM
08/16/17 06:10 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Just curious if you are sure on the size's ? As I see the one company posted by 70AARCuda has spacers to put a 3/64 ring in a 5/64 grove as they offer a .032 spacer which is 2/64. Ron
