Page 3 of 4 1 2 3 4
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2353323
08/13/17 07:22 PM
08/13/17 07:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
A 383 was around then right.................. work
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2353332
08/13/17 07:50 PM
08/13/17 07:50 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What happened to the stock block rule?
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2353337
08/13/17 08:12 PM
08/13/17 08:12 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Originally Posted By Lifsgrt
Update- decided to go with THE block (which I have received),at 4.500" bore and 3.915" stroke to net 499". Machine work is being done and engine built by Best Machine, as I'm sure Chuck and Pete will make way more power than I could. Will be using a motor plate to fit a dry sump pump. Still shooting for 950hp+ NA. As of now, I'm inside of a year to have the car built...should be a piece of cake!
I would think they would make more like over a 1000 HP easy Jerry. You will be turning it up in the RPM range, like 9000+ though I would think.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2353567
08/14/17 12:35 PM
08/14/17 12:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
That's 25" smaller than my M/C deal was that ultimately got well over 1050hp. Don't see 950 being to difficult as mine was far from a max effort deal. Went 171 in a 2975lb car so you can do your own math.
Re: B1 MC heads for a 500" RB [Re: Al_Alguire] #2353799
08/14/17 06:48 PM
08/14/17 06:48 PM
dogdays Offline
dogdays  Offline
The Bonneville Salt Flats is, IIRC, 4200 feet elevation. That's an automatic 15% derate in horsepower.
Oh, rats, I see you've already covered the Density Altitude of 7700 feet.
5280 is -20% at standard temp and pressure, so the 7700 would be something like 33%?
R.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2353830
08/14/17 07:31 PM
08/14/17 07:31 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Well, I live and race here. It's not 33%, more like 15% in 8500 ft corrected.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2353876
08/14/17 09:01 PM
08/14/17 09:01 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I think more people need to come and experience what we get to experience out the west. A lot of things go into factoring a DA. I don't think they understand the barometer is 25 there...It has a way of kinda killing an NA car. I don't know the correction factor for RMR but it has to be .95XX given the altitude. Even NHRA slows indexes down .45 seconds there..
Re: B1 MC heads for a 500" RB [Re: WO23Coronet] #2353979
08/15/17 12:09 AM
08/15/17 12:09 AM
near St Petersburg, FL
Lifsgrt Offline OP
Lifsgrt  Offline OP
Rulebook says same material as original block, all OE parts must bolt up, etc. I'm going with close enough. Didn't want to build a time bomb 400 block. This block is approved for NHRA SS as I understand it, so I'm rollin' with that.
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: B1 MC heads for a 500" RB [Re: Al_Alguire] #2354146
08/15/17 11:48 AM
08/15/17 11:48 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
seconds there..
Last correction factor was 1.27 at 8150 ft corrected. The car is typically .3 slower from Las Vegas, and there is a whole bunch of variation there.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2354164
08/15/17 12:22 PM
08/15/17 12:22 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well and we both know Vegas is at least .2 slower than most tracks. Poorly tuned combos will be even slower. But its a fun experience in all the thin air around here. I know we are celebrating if the barometer reached 28, its party time and we are gonna FLY!!!
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2354429
08/15/17 07:54 PM
08/15/17 07:54 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Right on, that makes it easier! (originally it looked like you needed to use a stock block)
Re: B1 MC heads for a 500" RB [Re: WO23Coronet] #2577786
11/13/18 01:48 AM
11/13/18 01:48 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
So, the 499" Bonneville bullet based on a B "THE BLOCK" is almost finished at Best Machine Racing Engines. Unfortunately, I need to bring it home to FL, install and plumb the dry sump and have headers built prior to taking it back for the dyno session, so the numbers will still be a while. Hoping for 1000hp NA. It has been and continues to be a long road, but still planning to make Speed Week 2019!
46099014_1982787495110257_6465589156889231360_n.jpg46099014_1982787495110257_6465589156889231360_n.jpg45322733_1973239259398414_2462041233078353920_n.jpg
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2577792
11/13/18 02:03 AM
11/13/18 02:03 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I've been watching the build at Best and it sure is a nice piece. You picked a great shop to do the build and I'm sure you will be more then pleased.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2577816
11/13/18 04:47 AM
11/13/18 04:47 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Hey Jerry,
New Bullet looks fantastic....i'm sure it'll run just as good as it looks !
Sent you a PM wave
Ron
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2577988
11/13/18 05:06 PM
11/13/18 05:06 PM
K
KOS Offline
KOS  Offline
K
whats the deal with the water pump and belt driven distributor?do you have spacers to push it forward?its hard to tell in the pic.nice build btw
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2577998
11/13/18 05:42 PM
11/13/18 05:42 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
that's a nice piece. Chuck knows how to make HP for sure! I bet it makes more than 1000. Best of luck
....BAD A$$ STREET CAR.....
Re: B1 MC heads for a 500" RB [Re: n20mstr] #2755022
03/23/20 01:25 PM
03/23/20 01:25 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
These heads proved to work well for this 498" B-block endurance build. Made 947hp @7400rpm and 690tq@6800rpm on Best Machine's dyno.
KOS, not sure about spacers, I think the motor plate takes care of it. Best Machine could answer that.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2755027
03/23/20 01:34 PM
03/23/20 01:34 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
KOS, I went with the Jesel timing belt drive and distributor based on Best Machine's recommendation. Timing belt due to cam and valvetrain harmonics, and the distributor to have a bigger cap to lessen likelihood of crossfiring. This engine will be WOT for up to two plus minutes at a time.
The Meziere water pump I chose because of flow rating and to free up some power. After going down this path, I spoke with Meziere and they said a mechanical pump would have been better...so time will tell. I did get a custom Saldana radiator for this project, so hopefully it will work.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2755052
03/23/20 02:44 PM
03/23/20 02:44 PM
Cab_Burge Online work
Cab_Burge  Online Work
Do you think you will make it out here this year? If so the early SCTA race or the later BNI race?
How hard is it to get a room when the races are on?
I'm still watching you on this up
I decided to not try and make the car I wanted to build after they both drop the all wheel drive classes whiney
Re: B1 MC heads for a 500" RB [Re: Cab_Burge] #2755149
03/23/20 06:02 PM
03/23/20 06:02 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Yes, if Speed Week occurs I plan to be there. Still need a few bits and pieces (driveshaft, a pair of 28" Moroso DS-2s, and a fee other odds and ends), and have a ton of work to do, but I have most all the systems to get it together, just have to get it all installed. I am focussing on it to try and get it done this year, at least for the maiden run!
Page 3 of 4 1 2 3 4
