- where to hook vacuum line for distributor
- manifold has large port and couple small ones, larger to booster, smalls ones?
- PCV valve runs to?
- Should I use the 3 nipple breather and run one to tank, one to PCV and one to air cleaner?
- Or should I use the single 70 style breather?
Any help is much appreciated!! Thanks Moparts!!
- the vacuum line goes to the small nipple in the metering block of the center carb
- manifold should have a threaded port in the back, install large nipple there, that is where the brake booster hose goes
- PVC hose routes around the back of the motor and connects to the base of the center carb
- 71s ALL have the three nipple breather the big hose goes to the air cleaner, the center carb should have a bowl vent, connect a hose from the vent to the breather, the last hose goes to a 5/16 fuel line that goes back to the fuel separator in the truck (not the tank)
