Trans line pressure without linkage #2353204
08/13/17 02:08 PM
08/13/17 02:08 PM
Ks
P
pullandrag Offline OP
P
Ks
Maybe stupid question but am firing a fresh 440 in the morning and don't have any trans linkage to carb I'm not a transmission guy but I remember in high school baling wiring the 904 lever for more pressure (stupid kid) but do I need that spring loaded arm to kickdown to have any kind of pressure to just break in a engine or just full of fluid OK???Thanks
Re: Trans line pressure without linkage [Re: pullandrag] #2353208
08/13/17 02:12 PM
08/13/17 02:12 PM
A727Tflite Offline
A727Tflite  Offline
As long as you don't drive it the kick down linkage is not in play. Even moving it in the drive or garage is fine w/o the linkage hooked up. Just don't put much torque in to it if you do decide to move it.
Re: Trans line pressure without linkage [Re: pullandrag] #2353245
08/13/17 03:20 PM
08/13/17 03:20 PM
Ks
P
P
Ks
Transman thank you😀!
