70 HEMI Challenger fenders how were they rolled ?
#23525
02/27/06 05:19 PM
02/27/06 05:19 PM
Hopefully someone can help me out of a jam? I took my 70 HEMI Challenger to be re-painted and before I could stop them the painter smoothed out the fenders and even welded back the cut outs thinking one of the previous owners had done the rolling and cutting to clear some old tires. Now I am faced with rolling back and cutting the fenders back to the way the factory did it in 1970.
Can anyone help with some photo's or information on how Dodge rolled them back in 1970? It didn't appear to me that they used a tool back then other than a hammer to make them clear the tires? It was a pretty crude job of cutting and rolling from my recollection on what were factory original HEMI fenders.
Thanks.
Re: 70 HEMI Challenger fenders how were they rolled ?
[Re: Mastershake340]
#23529
02/27/06 06:56 PM
02/27/06 06:56 PM
That lip looks really smooth compared to my fenders before they were accidently repaired. Mine looked like they were hammered as opposed to rolled.
#23530
02/27/06 10:07 PM
02/27/06 10:07 PM
Posts: 2,304 WI
RestoRick
WI
Yes...they definitely had a hammered look! Not the greatest picture, but should give you an idea.... also, there was no additional cutout... the cutout that your guy filled was also found on regular fenders. The lip is just beat up... A more careful tapping up will give the best results... The drag about it is that even the most careful bending with give you some distortion to work out on the side of the fender. Rick
[Re: RestoRick]
#23531
02/27/06 10:20 PM
02/27/06 10:20 PM
Posts: 163 Fremont, CA
JDRacing
Fremont, CA
Rick, that's really an interesting and great picture. What's particularly interesting to me is that it looks just like the fenders on my '70 Hemi Challenger, with just about the same length of the lip rolled as on mine. The pictures MasterShake posted on his NOS/'71(?) fender shows a much longer length of the lip rolled than on either my fenders or your picture.
This continues my suspicion that there was a difference in the "Hemi Fenders" between the two years, and the cars on the line (mine are the original fenders) in '70 go somewhat shorter length of rolls than the next year (when they actually started putting "Hemi Fender" tags on Challengers). I've never seen one of those tags on a '70 Challenger (Cuda, yes), but maybe others have.
#23532
02/27/06 10:42 PM
02/27/06 10:42 PM
The best and easiest way to roll them is with a baseball bat. Since they are tapered and round. You just have the car driven forward as you roll the bat between the tire and the fender opening. you can start out with a small roll and increase it as to your liking by moving the bat to the larger end.
[Re: JDRacing]
#23533
02/28/06 12:01 AM
02/28/06 12:01 AM
Posts: 2,304 WI
RestoRick
WI
Rick, that's a really an interesting and great picture. What's particularly interesting to me is that it looks just like the fenders on my '70 Hemi Challenger, with just about the same length of the lip rolled as on mine. The pictures MasterShake posted on his NOS/'71(?) fender shows a much longer length of the lip rolled than on either my fenders or your picture.
The whole rolled fender thing is a bit of hit or miss thing on production vehicles... including 71... I've seen many original paint Hemi 70 AND 71 Cuda's and Challengers without the lip rolled!
Don't even think about using a baseball bat!!! That method is a sure fire way to end with a badly bowed fender... I'd suggest working with the fender off the car on a bench or work table. Using a roof rail dolly (comma shaped), on the backside of the lip while slowly and gradually softly tapping it over a little at a time, moving from end to end. The tip of the dolly is kept a little inboard from the outside of the fender, this helps minimize distortion on the outside by forming a small shoulder.
Rick
[Re: RestoRick]
#23534
02/28/06 12:13 AM
02/28/06 12:13 AM
JDRacing
Fremont, CA
Great information, Rick. Thanks very much.
Jeff
[Re: RTDaddy]
#23538
03/01/06 03:56 PM
03/01/06 03:56 PM
Thanks for all the photo's and help.
Do any of you guys know what color black and what texture or paint to use on the top of the cowl? One of the previous owners repainted the engine compartment and painted the cowl the body color.
