My brake pedal can back out of the master!!! #2352711
08/12/17 03:27 AM
08/12/17 03:27 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Am I missing a part? This is a 68 road runner manual brakes
Let's see if you can see this image
https://www.flickr.com/photos/153614762@N02/?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: My brake pedal can back out of the master!!! [Re: Kam*Kuda] #2352720
08/12/17 04:36 AM
08/12/17 04:36 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
there should be a rubber piece that goes on the end of the rod,there is a groove that the rubber fits in, it is what holds the rod in the master.
Re: My brake pedal can back out of the master!!! [Re: Kam*Kuda] #2352754
08/12/17 10:53 AM
08/12/17 10:53 AM
Andrewh Offline
Andrewh  Offline
did you replace the master recently?
manual masters have a grove for that rubber, but power ones might not, so even with the grommit it could pull out.
Re: My brake pedal can back out of the master!!! [Re: Kam*Kuda] #2352784
08/12/17 11:58 AM
08/12/17 11:58 AM
have your parts house cut a piece of vacuum line of the right dia (7/16 iirc but don't quote me), just long enough to slide on the end of the pushrod into the groove on the end like in the pushrod in the pic. The tailor made ones have a thin/shallow groove lengthwise along the neoprene piece which might be to let the air out as it is installed into the tapered blind hole or it might be nothing & just from how it was held when it was mfr'd. Lube it, as it is a tight fit.
Re: My brake pedal can back out of the master!!! [Re: RapidRobert] #2352795
08/12/17 12:29 PM
08/12/17 12:29 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
I do have the rubber piece It stays in place but if I pull back on the pedal it will come out
I looked at my cuda and this cant happen with that setup
It seems a safety issue. A local car had this happen on the track and had no brakes with disastrous results
I was going to weld in a bracket to create a stop to prevent it from being able to be backed out.
I was wondering if I was missing a part on the pedal assembly
1654.5 Mustang
1955 Land Rover
Re: My brake pedal can back out of the master!!! [Re: Kam*Kuda] #2352811
08/12/17 12:58 PM
08/12/17 12:58 PM
Look down in the rear piston "thimble" in the back of the MC & there must be a shallow but wide circular groove about halfway down for the neoprene piece to lock into as opposed to it being a smooth taper like a sewing thimble, otherwise it just pulls back out like it is doing. manual brake MC's must have that recess. power brake MC's can function with or with out the recess cuz they are setup different & as you know you want the right piston bore diameter for your app. EDIT Rick Ehrenberg iirc used silicone to lock it in there which I thought would be risky but Eberg has forgotten more info than I know so I would be OK with that as a solution.
Re: My brake pedal can back out of the master!!! [Re: Kam*Kuda] #2352852
08/12/17 02:38 PM
08/12/17 02:38 PM
I had that happen on my old drag Duster at LACR, luckily the shut down area was up hill and the track was long boogie I ended up using some plumber tape on the pedal mounting brakets to make sure that would happen again scope
I had replace that master cylinder and omitted the retaining ring tsk realcrazy
I'm lucky I survived that deal without hurting me or the car boogie
Re: My brake pedal can back out of the master!!! [Re: Kam*Kuda] #2352900
08/12/17 05:18 PM
08/12/17 05:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In some installations the brake light switch will prevent the pushrod from backing out; looks like yours is missing.
Fabricate a bracket to act as a pedal up stop.
Re: My brake pedal can back out of the master!!! [Re: John_Kunkel] #2352949
08/12/17 06:57 PM
08/12/17 06:57 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
yes I will fabricate something
The car is a procharged bb so its getting quicker and I could get into problems fast
1654.5 Mustang
1955 Land Rover
Re: My brake pedal can back out of the master!!! [Re: Kam*Kuda] #2353023
08/12/17 11:22 PM
08/12/17 11:22 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I was wondering if I'd have that problem in my '55 Plymouth given that there's no groove on the pushrod to hold a rubber ring. But, it seems to stay in just fine.
Re: My brake pedal can back out of the master!!! [Re: 71charger] #2353315
08/13/17 06:35 PM
08/13/17 06:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '55 has a positive pedal up stop...the BL switch is on the master cylinder.
