Re: Temerature sensor
[Re: rth]
#2352781
08/12/17 11:51 AM
08/12/17 11:51 AM
RapidRobert
^^^ do that & also you might ground the body (not the threaded shank) to a nearby ground (best would be to go all the way to the batt neg post) & see if it straightens out.
[Re: ct440rod]
#2352885
08/12/17 04:31 PM
08/12/17 04:31 PM
Posts: 15,377 Omaha Ne
TJP
Omaha Ne
1. Wrong or bad sending unit. 2. Bad ground on sending unit. 3. Wiring issue. 4. Guage needs to be calibrated. Have a radio shack nearby ?? You can check the gauge and wiring with 3 resistors jumpered between the sending unit wire and ground. 10 ohms of resistance should read near high 30 ohms should be about mid point 80 ohms should read Cold When doing the above test allow the gauge to stabilize for about 2 or so minutes
[Re: ct440rod]
#2353210
08/13/17 02:17 PM
08/13/17 02:17 PM
TJP
Omaha Ne
So if sending unit reads 474 cold on bench it probably the wrong sensor ? ? Possibly, one would need the resistance spec's for that particular sender though. Your question did give me another thought, One could warm the motor up to operating temp and take a resistance reading on the sender. knowing that 30 ohms should be about mid point on the gauge it might give an indication of whether the sending unit is the culprit. The best approach though is doing the resistor test previously mentioned.
[Re: ahy]
#2357359
08/21/17 12:26 AM
08/21/17 12:26 AM
RapidRobert
with a confirmed temp reading I would want an actual 180 water temp at a bare minimum. someone said something about some duct tape needed on shiny surfaces for a correct IR gun reading (not my area just a FYI). yes some gauges can be adjusted, look in the back side of it.
[Re: ct440rod]
#2359323
08/24/17 09:08 PM
08/24/17 09:08 PM
TJP
Omaha Ne
New Sensor put not sure where I bought it. I will look for a 40 ohm resistor and see see if gauge goes 1/2 way and go from there. Have a radio shack nearby ?? You can check the gauge and wiring with 3 resistors jumpered between the sending unit wire and ground. 10 ohms of resistance should read near high 30 ohms should be about mid point 80 ohms should read Cold When doing the above test allow the gauge to stabilize for about 2 or so minutes
