cyl ring spacers, where to get em
#2352697
08/12/17 01:40 AM
08/12/17 01:40 AM
RapidRobert
I have some pistons with std 3/16 top/2nd ring grooves & I have some 1/16 rings. I believe there are spacers to allow them to be used. Who sells em & do they work OK? thank you for your time.
Re: cyl ring spacers, where to get em
[Re: RapidRobert]
#2352812
08/12/17 01:05 PM
08/12/17 01:05 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Robert if IRC they were called GI spacers.Had a set installed on a 361 I had years ago.Machine shop had them.Ran that engine for like 3 years with no problems.Pulled it to put in a 440.Rocky
Chrysler Firepower
[Re: therocks]
#2352823
08/12/17 01:19 PM
08/12/17 01:19 PM
RapidRobert
I Googled GI spacers & some ring mfr's came up so I will go after some of them. thank you!
[Re: RapidRobert]
#2352850
08/12/17 02:32 PM
08/12/17 02:32 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
How much are the spacers compared to the correct ring set? BTW, are those rings grooves for 5/64 rings or 3/16?
[Re: RapidRobert]
#2352882
08/12/17 04:25 PM
08/12/17 04:25 PM
therocks
Niles , Ohio
Mine at the time was because the lands were too big.It was cheaper than pistons.IIRC all the machine work they did plus the spacers was like 50 bucks.Rocky
Chrysler Firepower
[Re: therocks]
#2352888
08/12/17 04:39 PM
08/12/17 04:39 PM
RapidRobert
I did knot know they required machine work. if so (for my app) then I should continue to try to sell my 1/16 rings & get a set of regular 5/64 rings (30 over 440 daily driver)
[Re: RapidRobert]
#2352899
08/12/17 05:13 PM
08/12/17 05:13 PM
Posts: 25,871 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Machine work depends on whether you're just using the GL spacers to reduce the groove size for standard width rings or using them to repair worn grooves.
[Re: RapidRobert]
#2352926
08/12/17 06:19 PM
08/12/17 06:19 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#2353770
08/14/17 05:56 PM
08/14/17 05:56 PM
RapidRobert
I just got off the ph with Total Seal & the salesman said that they do not offer a spacer for 5/64 down to 1/16 & that he is not aware of any one else in the industry that does... Man I'd sure think that'd be a common (desired) item. I'd sure hate to think he (Ed) was lying just to possibly drum up a sale.
[Re: RapidRobert]
#2353782
08/14/17 06:10 PM
08/14/17 06:10 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
You're talking about a .015625" spacer.
Doesn't seem like that would be super durable.
[Re: fast68plymouth]
#2353886
08/14/17 09:21 PM
08/14/17 09:21 PM
RapidRobert
Yes they (total seal) have .030" and .046" spacers for 2 rings that are even thinner than 1/16".
#2354669
08/16/17 05:55 AM
08/16/17 05:55 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Doesn't seem like that would be super durable. I was thinking its very thin as 1/16 is 4/64 so the spacer would be 1/64 which is what Dwayne posted. Ron
[Re: RapidRobert]
#2354671
08/16/17 06:10 AM
08/16/17 06:10 AM
383man
Balt. Md
I just got off the ph with Total Seal & the salesman said that they do not offer a spacer for 5/64 down to 1/16 & that he is not aware of any one else in the industry that does... Man I'd sure think that'd be a common (desired) item. I'd sure hate to think he (Ed) was lying just to possibly drum up a sale. Just curious if you are sure on the size's ? As I see the one company posted by 70AARCuda has spacers to put a 3/64 ring in a 5/64 grove as they offer a .032 spacer which is 2/64. Ron
