Re: replacing crankshaft - dimensions needed
[Re: willard]
#2351927
08/10/17 03:44 PM
08/10/17 03:44 PM
Posts: 25,866 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The nominal dimension is 2.8125" but will vary slightly because of the knurling. Same dimension for the RB crank.
[Re: John_Kunkel]
#2352452
08/11/17 04:20 PM
08/11/17 04:20 PM
dogdays
A 361 crank is the same, as is a 400 forged crank. The 383 and 400 cast cranks require external balancing but are the same dimensionally.
I'd think you could have a forged 383 crank shipped from the States without breaking the bank because stock stroke 383 cranks are not in high demand. Everyone and his brother are going stroker.
So the crank has had the rear slinger machined off? I can't wrap my head around that one. There should be no earthly reason to do it.
R.
