What oil for 833 race car.
#2351860
08/10/17 01:35 PM
08/10/17 01:35 PM
Posts: 48 the Netherlands
dutchrunner
the Netherlands
Friend has rebuild 833 for his 70 RR. He's racing the car and was wondering what's the best oil to use and why. Thanks for info.
1969 Roadrunner Sox&Martin tribute with 572Hemi and F&B performance Six-Pack XFI2.0 injection.
Re: What oil for 833 race car.
[Re: dutchrunner]
#2351864
08/10/17 01:38 PM
08/10/17 01:38 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
A couple of racers here on Moparts recommended Pennzoil Synchromesh oil for the hemi 4 speed in my dad's 6 pack road runner. It's just a street car, but seems to work great.
[Re: dutchrunner]
#2351871
08/10/17 01:48 PM
08/10/17 01:48 PM
dutchrunner
the Netherlands
He had some light oil in it from grey can. Doesn't know name.
[Re: dutchrunner]
#2351874
08/10/17 01:54 PM
08/10/17 01:54 PM
Posts: 3,076 Michigan
A727Tflite
If you are using the regular brass sync rings all you need is good quality auto trans fluid. That's all we have ever used in the 833 in a drag application, dating back to the late 60's. Works great when it gets cold out too. We used it in the old overdrive units based off the same design as the 833 for field complaints of high shift effort when very cold. These older units were called New Process 440's. Some people will tell you the trans will fail with this fluid - we ran them behind pro-stockers before the Lenox showed up and we used them in MP, Comp, SS and Stock Eliminator cars this way too. Never saw an issue in any application. Not to confuse - the units used In drag racing were the 833, not the 440.
[Re: A727Tflite]
#2351878
08/10/17 02:00 PM
08/10/17 02:00 PM
Posts: 1,505 TN
SCATPACK 1
TN
If you are using the regular brass sync rings all you need is good quality auto trans fluid. That's all we have ever used in the 833 in a drag application, dating back to the late 60's. Works great when it gets cold out too. If I'm not mistaken we used it in the old overdrive units based off the same design as the 833. I think they were called 440 models. Chrysler used auto trans fluid in the overdrive 4 speeds. BUT they had issues with premature wear on the thrust bearings and synchro rings. We received a service bulletin when I worked at the dealership in the 80's that said replace the auto trans fluid with regular 30 or 40 weight engine oil. IF you guys will remember in the 60's and 70's transmissions came with something like 90 weight gear oil in them. I ran 30 weight oil in my Super stock Hemi 833 Hemi trans with a little bit of STP for the slick stuff it had in it. Never had an issue.
Old Geezer Racing
[Re: A727Tflite]
#2351912
08/10/17 03:02 PM
08/10/17 03:02 PM
Posts: 1,073 oregon
greendart408
oregon
If you are using the regular brass sync rings all you need is good quality auto trans fluid. That's all we have ever used in the 833 in a drag application, dating back to the late 60's. Works great when it gets cold out too. We used it in the old overdrive units based off the same design as the 833 for field complaints of high shift effort when very cold. These older units were called New Process 440's. Some people will tell you the trans will fail with this fluid - we ran them behind pro-stockers before the Lenox showed up and we used them in MP, Comp, SS and Stock Eliminator cars this way too. Never saw an issue in any application. Not to confuse - the units used In drag racing were the 833, not the 440. Agreed, My dads 73, 340,4spd duster he bought brand new had ATF in it, still has today, been thrashed at the track it's whole life and has 100k on the odo. Best shifting trans I have ever shifted, feels and works like brand new.
[Re: dutchrunner]
#2351976
08/10/17 05:09 PM
08/10/17 05:09 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The SAE grading for motor oil and gear oil is not the same.
70w80 gear oil is about the same viscosity as 15w50 motor oil.
[Re: SCATPACK 1]
#2352076
08/10/17 08:45 PM
08/10/17 08:45 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
[quote=Transman] IF you guys will remember in the 60's and 70's transmissions came with something like 90 weight gear oil in them. Not all production early Mopar muscle cars with NP833 came with 90 wt. gear oil in them, a lot of the cars sold new in the colder climates had ATF in them from the factories starting in 1965 or 1966 I had a 1965 Dodge Coronet 500 361 that came from new England that had ATF in it from day one according to the original owner I lived in the Mojave Desert at that time and switched the ATF fluid out to 90 Wt. gear oil, not a good idea in the winter I put ATF back in it and used ATF in all my NP833 after that, race only or street and strip
[Re: dutchrunner]
#2352079
08/10/17 08:53 PM
08/10/17 08:53 PM
Posts: 4,457 Washington
madscientist
Washington
It's 2017. No need to use ATF. A good synthetic gear oil will allow easy shifting in all climes. The bearings will thank you.
[Re: dutchrunner]
#2352317
08/11/17 09:54 AM
08/11/17 09:54 AM
Posts: 608 TN
1DGEMAN
TN
Redline MTL is the way to go. It is what I put in our V code Cuda. I also run it in my Jericos.
Real Men shift for themselves
[Re: 1DGEMAN]
#2352458
08/11/17 04:27 PM
08/11/17 04:27 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Dexron ATF here also. Works fine for me..
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: dutchrunner]
#2352626
08/11/17 10:36 PM
08/11/17 10:36 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
My 65 has had 80w gear grease since I got it in 69.Was OE at the time and stillhas gear grease in it.It was a daily driver for years with gear grease and never a problem shifting.Rocky
Chrysler Firepower
