Page 2 of 4 1 2 3 4
Re: CNC porting iron heads. [Re: mopar65] #2346342
07/31/17 06:27 PM
07/31/17 06:27 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By mopar65
Originally Posted By 370hemi
KG engines in Ohio 419 806 5870 has a max wedge CNC program for the 906
My friend is runing a set of KG CNC ported 906 and told me he is going to get a set of there max wedge CNC ported 906 next. He has been ran 10.40 at 130 in the 1/4 on E85 so far.
Unless he MUST run OEM iron heads, there are too many good aftermarket head choices today to bother throwing big $$$ into 50 year old iron passenger car heads.
Re: CNC porting iron heads. [Re: 411Dude] #2346516
08/01/17 12:12 AM
08/01/17 12:12 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I don't mind doing a "normal" port job on iron heads....... But if someone is looking for a "max effort" type of job...... I'm not the guy.
Re: CNC porting iron heads. [Re: 411Dude] #2346591
08/01/17 09:16 AM
08/01/17 09:16 AM
an8sec70cuda Offline
Given the core shift issues that the factory heads have, wouldn't a CNC ported set tend to be even more crack prone? Going fast w/ stock stuff is cool and all, but at some point it becomes even more of a money pit than racing already is.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'70 'cuda, 575" Hemi, 727, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
'17 Ram 1500 5.7 Hemi
Re: CNC porting iron heads. [Re: BradH] #2346597
08/01/17 09:27 AM
08/01/17 09:27 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Hey Brad how's the new engine build coming along? But yes my friend is tuning in a class that you have to run stock factory blocks and heads. Kind of like the fast class but for poor guys.lol
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: CNC porting iron heads. [Re: an8sec70cuda] #2346631
08/01/17 11:27 AM
08/01/17 11:27 AM
So. Burlington, Vt.
So. Burlington, Vt.
I've thrown away a lot of really nice ported OE heads that made pretty good power and the owners were pretty happy with how the cars ran. Some of them I ported, some were ported at other shops.
For big blocks, when they're heavily modified(especially with big intake valves), the two most common places for cracking is across the intake seats into the bowls, and externally under the two center exhaust ports.
Of course, if you're racing in a class where they're required, you don't have a lot of options;
-Port them less(go slower)
-Don't port them at all(go even slower)
-Accept that the heads may not last all that long.
Re: CNC porting iron heads. [Re: an8sec70cuda] #2346635
08/01/17 11:36 AM
08/01/17 11:36 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Probably just the opposite. Most CNC programs are set up on the safe side so they can move product in and out the door. Most hand porters can take a CNC'd head and make vast improvements in flow. I have never had a set of CNC'd heads leave my shop that weren't better and I'm not talking about a few cfm but then again I love playing on the flowbench.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: CNC porting iron heads. [Re: 411Dude] #2346640
08/01/17 11:41 AM
08/01/17 11:41 AM
So. Burlington, Vt.
So. Burlington, Vt.
I think John could use a nice high effort iron head porting job to help fill up some of his leisure time.
Plus it would be nostalgic........ Bringing back memories of 30 years ago when porting iron was the only option.
I've had a couple sets of iron MW heads in my shop that were ported by a pretty high profile non-Mopar engine builder. These were fairly high effort(high dollar??) jobs, that looked very nice.
One set was some OE 286 heads, the other was the latest version of the 518M heads.
I'll just say that neither set had the kind of flow numbers I've heard that these heads are capable of........ Although they flowed basically the same as what I've gotten out of them with my "normal" port job.
Admittedly....... I'm not into fixing holes...... So I err on the conservative side...... Which means there is some flow left on the table.
Re: CNC porting iron heads. [Re: fast68plymouth] #2346651
08/01/17 11:54 AM
08/01/17 11:54 AM
PA.
"Little"John
"Little"John
PA.
I think John could use a nice high effort iron head porting job to help fill up some of leisure time.
I think John has a set of Edelbock small block heads sitting on his bench with .350 off-set rockers waiting for him to pick up the dam grinder again.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.38@138.67
Re: CNC porting iron heads. [Re: pittsburghracer] #2347145
08/02/17 05:20 AM
08/02/17 05:20 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Larry Meaux would be someone I would consider talking to, along with those already mentioned.
Alan Jones
Re: CNC porting iron heads. [Re: 411Dude] #2347243
08/02/17 11:57 AM
08/02/17 11:57 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Jerry Branch pointed out 50 years ago that "shiny!" is a waste of time, but the customer expects it.
Except to examine symmetry (are the gasket outlines followed accurately? Are all of the left or right-handed ports identical in interior shape? Is the guide exposure the same?), appearance is almost worthless unless you know that the porter has excellent past performance with that casting.
Everything else is just cosmetic.
A CNC program developed for a 906 will do the following on a 518:
1. add 50 hp
2. subtract 50 hp
3. break them
4. no one knows
</rant>
Boffin Emeritus
Re: CNC porting iron heads. [Re: mr_340] #2348251
08/04/17 12:01 AM
08/04/17 12:01 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Originally Posted By mr_340
Originally Posted By 1DGEMAN
Good luck with MCH.
Misery loves company. I have $4k tied up in some aluminum SS Hemi heads for over a year. Bob doesn't even tell me where they are in the queue. A little communication would be nice, a quick e-mail every other month would be nice.
I drove up to Detroit this week and met with Bob today. We had a good chat about my heads and he said he would run them next week. I'll post if my engine guy in Tampa gets the heads in the next couple of weeks with a report.
Floyd Lippencott IV
Re: CNC porting iron heads. [Re: fast68plymouth] #2349237
08/05/17 11:27 PM
08/05/17 11:27 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Not to take ANYTHING away from what Dwayne is saying here but, I did epoxy patch a set of heavy ported/milled!!! 906's that were cracked externally below the exhaust ports and that repair held well for a good number of years/passes.
Re: CNC porting iron heads. [Re: 411Dude] #2349267
08/06/17 12:10 AM
08/06/17 12:10 AM
So. Burlington, Vt.
So. Burlington, Vt.
Personally, I would never run a bb mopar head with the crack under the exhaust ports that had been repaired that way, in a racing situation.
I've had two motors on the dyno that developed cracks there.
They didn't leak a drop until you started applying a load and making power.......when the head is trying to get lifted off the block, that crack opens up and it's like you turned on a garden hose, with coolant spraying out.
Back out of the throttle.........the flow just stops.
After seeing it first hand on two occasions.........I don't wanna be the guy behind the wheel when it lets go and gets under the tires.
Re: CNC porting iron heads. [Re: 411Dude] #2349671
08/06/17 06:49 PM
08/06/17 06:49 PM
Montana Flathead county
411Dude Offline OP
411Dude  Offline OP
Thanks, all. We are building a "230" block 400 with a de-stroked 383 crank for a class at Bonneville in a roadster. Looking for somebody to set up our max wedge heads. They may not need much work at this cu. in. level but we plan on needing to run the rpms up higher than any super stock wedge so need a max effort creativity on the valvetrain setup. Planning to run Hilborn injection on gas. Dry sump.
Re: CNC porting iron heads. [Re: 411Dude] #2349696
08/06/17 07:38 PM
08/06/17 07:38 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
I hope that you post more on this build
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: CNC porting iron heads. [Re: 411Dude] #2349700
08/06/17 07:45 PM
08/06/17 07:45 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
others may disagree but, a max wedge port is WAY to big for that CID, just my opinion.
Re: CNC porting iron heads. [Re: 411Dude] #2349819
08/06/17 10:57 PM
08/06/17 10:57 PM
I know several Mopar sponsored NHRA SS class racers that raced 383 back in the late 1970 and early 1980s, they where shifting them at or above 8400 RPM back then with that technology back then pushing the NHRA rules to the limit devil
On your deal how long do you get to push the race car before letting out the clutch ?
The reason I'm asking is the cam and getting the motor up to RPM that it will start to pull good before wind resistance gets in the mix work
Re: CNC porting iron heads. [Re: 411Dude] #2350184
08/07/17 04:05 PM
08/07/17 04:05 PM
warren, mich.
dwayne welder Offline
warren, mich.
TheMax Wedge head is to big for that application it won't make any torque or rev up fast!!!
Re: CNC porting iron heads. [Re: 411Dude] #2350261
08/07/17 06:27 PM
08/07/17 06:27 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
They are no bigger than the apache head on a 6.4. Send em to someone who knows those heads and let em at em. Try to keep some material in the exhaust port to keep it from cracking and cam apropriately. A max wedge head is just fine if you build the rest of the motor/car to match the RPM range.
Re: CNC porting iron heads. [Re: 411Dude] #2350270
08/07/17 06:53 PM
08/07/17 06:53 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
It should work and work well. The big bore (4.340) short stroke will be great.
How is it the Chevy guys can run 500Plus cfm heads on there stuff and we somehow cannot run heads that will NEVER see 350 on ours? I would be curious to see your rule package as to what your allowed. I know that some of the Classes out on the salt can result in some interesting packages. I used to work on a guy who ran a 291 cid Desoto hemi out there years ago. Different and neat.
Todd
Page 2 of 4 1 2 3 4
