Re: BGE 6.4 Truck engine in an earlier 5.7 truck chassis
[Re: WO23Coronet]
#2350277
08/07/17 08:11 PM
08/07/17 08:11 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I've pondered this as well. I can't see why it wouldn't, plenty of big cam stroked 03-08 rams running around. My only thought is will a BGE 6.4 take an early 5.7 tone wheel on the crank? Guess you'd have to run an early cam sensor as well (and lock out be cam)? I believe you are correct. Does the 6.4 truck engine have Variable intake runners?
[Re: WO23Coronet]
#2350514
08/08/17 03:32 AM
08/08/17 03:32 AM
Posts: 990 Norwalk, Ohio
sycboi
Norwalk, Ohio
My only thought is will a BGE 6.4 take an early 5.7 tone wheel on the crank? Guess you'd have to run an early cam sensor as well (and lock out be cam)? I think you're correct, but it would be an early 32 tooth 6.1 reluctor wheel because of the 4-bolt attachment to the crankshaft. The 5.7 only has the 3-bolt reluctor. Definitely have to lock the vvt cam out with a kit...
SuperBeast
An enforcer for the Mopar Mafia!
[Re: RTSrunner]
#2350720
08/08/17 02:24 PM
08/08/17 02:24 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
Locking out the VCT is super easy and no "kit" required. I can't finger out how to post pics or I would show you.
[Re: HotRodDave]
#2350751
08/08/17 03:14 PM
08/08/17 03:14 PM
sycboi
Norwalk, Ohio
Locking out the VCT is super easy and no "kit" required. I didn't realize that. Good to know. Following this thread close for tips and knowledge...
SuperBeast
[Re: RTSrunner]
#2350793
08/08/17 04:09 PM
08/08/17 04:09 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Droping the 6.4 in the 03-08 rams is easy, Lock out the VVT, Change the tone ring, and dump the intake, IMHO use a SRT 6.1 intake. there's some tuning but nothing outrages..unless you have an 03 Ram then I would swap the PCM over to the 05.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: WO23Coronet]
#2352005
08/10/17 06:16 PM
08/10/17 06:16 PM
ric3xrt
Trumbauersville PA
Would you have to change the cam sensor? For swapping the 03 to 05 PCM? or for swapping the 6.4 in to the earlier truck ?
