BGE 6.4 Truck engine in an earlier 5.7 truck chassis #2349813
08/06/17 11:48 PM
08/06/17 11:48 PM
Pittsburgh,PA
RTSrunner Offline OP
Pittsburgh,PA
Has anyone swapped(or tried to!) a 6.4 truck engine into an earlier (2003-2008) Gen III 5.7 powered truck? Wondering if the 5.7 computer could support a 6.4 with tuning and other compatability issues.
Thanks,RT
Re: BGE 6.4 Truck engine in an earlier 5.7 truck chassis [Re: RTSrunner] #2350002
08/07/17 12:28 PM
08/07/17 12:28 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I've pondered this as well. I can't see why it wouldn't, plenty of big cam stroked 03-08 rams running around. My only thought is will a BGE 6.4 take an early 5.7 tone wheel on the crank? Guess you'd have to run an early cam sensor as well (and lock out be cam)?
Re: BGE 6.4 Truck engine in an earlier 5.7 truck chassis [Re: WO23Coronet] #2350277
08/07/17 08:11 PM
08/07/17 08:11 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I believe you are correct.
Does the 6.4 truck engine have Variable intake runners?
Re: BGE 6.4 Truck engine in an earlier 5.7 truck chassis [Re: RTSrunner] #2350457
08/08/17 01:19 AM
08/08/17 01:19 AM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
6.4 has VVT and variable intake runner. I would talk to Arrington or Bouchilon and see what's been done.
Re: BGE 6.4 Truck engine in an earlier 5.7 truck chassis [Re: RTSrunner] #2350509
08/08/17 03:06 AM
08/08/17 03:06 AM
Pittsburgh,PA
Pittsburgh,PA
Thanks for the feedback guys,looks promising so far!
RT
Re: BGE 6.4 Truck engine in an earlier 5.7 truck chassis [Re: WO23Coronet] #2350514
08/08/17 03:32 AM
08/08/17 03:32 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
I think you're correct, but it would be an early 32 tooth 6.1 reluctor wheel because of the 4-bolt attachment to the crankshaft. The 5.7 only has the 3-bolt reluctor. Definitely have to lock the vvt cam out with a kit...
SuperBeast
An enforcer for the Mopar Mafia!
Re: BGE 6.4 Truck engine in an earlier 5.7 truck chassis [Re: RTSrunner] #2350720
08/08/17 02:24 PM
08/08/17 02:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Locking out the VCT is super easy and no "kit" required. I can't finger out how to post pics or I would show you.
Re: BGE 6.4 Truck engine in an earlier 5.7 truck chassis [Re: HotRodDave] #2350751
08/08/17 03:14 PM
08/08/17 03:14 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
I didn't realize that. Good to know. Following this thread close for tips and knowledge...
SuperBeast
Re: BGE 6.4 Truck engine in an earlier 5.7 truck chassis [Re: RTSrunner] #2350793
08/08/17 04:09 PM
08/08/17 04:09 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Droping the 6.4 in the 03-08 rams is easy, Lock out the VVT, Change the tone ring, and dump the intake, IMHO use a SRT 6.1 intake. there's some tuning but nothing outrages..unless you have an 03 Ram then I would swap the PCM over to the 05.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: BGE 6.4 Truck engine in an earlier 5.7 truck chassis [Re: RTSrunner] #2350978
08/08/17 09:28 PM
08/08/17 09:28 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Would you have to change the cam sensor?
Re: BGE 6.4 Truck engine in an earlier 5.7 truck chassis [Re: WO23Coronet] #2352005
08/10/17 06:16 PM
08/10/17 06:16 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
For swapping the 03 to 05 PCM?
or for swapping the 6.4 in to the earlier truck ?
Re: BGE 6.4 Truck engine in an earlier 5.7 truck chassis [Re: ric3xrt] #2352248
08/11/17 01:39 AM
08/11/17 01:39 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
For swapping the 6.4, would you have to use (could you use) an 03-08 5.7 cam sensor in a VVT engine (is it a bolt on)?
