Re: Motor mountsg block truck?
[Re: GKMOPAR]
#2348932
08/05/17 01:21 PM
08/05/17 01:21 PM
Posts: 91 Peoples Republic of Oregon
wayfarer
Common design for the 70' and 80's in trucks. The mounts that I have, including those still attached to a '76-77 B engine, show a slot that is right close to 2" in length on both pieces. Cannot find any A-LA mounts right now.
[Re: poorboy]
#2349877
08/07/17 01:43 AM
08/07/17 01:43 AM
RapidRobert
I never woulda guessed. Sometimes it ain't what you know its WHO you know!
[Re: poorboy]
#2350446
08/08/17 01:00 AM
08/08/17 01:00 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
The difference between the small block mounting brackets and the big block mounting brackets is the distance between the holes for the mounting ears at the motor. The mounting ear holes on a big block are farther apart then they are on a small block. In the picture, the bracket on the left appears to be a small block bracket, and the one on the right appears to be a big block bracket. Gene Those are 1972-80 2wd and 72-74 4wd. May be the same as 81-93 2wd???
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
