I doo what the voices in my head tell me to do,,,,,
#2348653
08/04/17 09:02 PM
08/04/17 09:02 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Well, not really. But that was funny. I had a card in the passengers window, and a pic of it got it put in with the article in Mopar Muscle back in 2002. Actually, been suffering from depression (have for decades) and was starting to listen to the thoughts of getting out of racing. Being tired, spending lots of money, you know the drill. Well, I pulled the car out of the trailer, fired it up and drove it around to the shop to put it on the rack for needed work. I thought DAM I LOVE THIS!! So, onward into battle! The car ran some super good, consistant numbers last outing. 8.910, and 8.909 on test day, the third pass I changed shift rpm to 7250 from 7450 and it didn't like it, 8.942. This was Friday test day, DA 2198 on the 8.910 pass, 2124 on the 8.909 pass. Saturday, got two passes in, 8.899 ,da 2380. Second pass, 8.894, da 2323. Now if the driver can get his shi- ah, stuff together, we can go some rounds!
Re: I doo what the voices in my head tell me to do,,,,,
[Re: gregsdart]
#2348657
08/04/17 09:07 PM
08/04/17 09:07 PM
gregsdart
Thanks, DG. Read about your getting daylight under the front
[Re: gregsdart]
#2348663
08/04/17 09:15 PM
08/04/17 09:15 PM
Posts: 5,080 organ
maximum entropy
organ
i feel your pain... follow your passion. it's good!
[Re: gregsdart]
#2348667
08/04/17 09:18 PM
08/04/17 09:18 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I feel for ya, Greg. I even sold my car, once. Worst day ever for me and my son. We both cried. 2 years later, I bought it back. Looked like crap after being sanded down and left outside for 2 years. But it's mine, almost done, and can't wait to get her down the track again.
[Re: sgcuda]
#2348674
08/04/17 09:29 PM
08/04/17 09:29 PM
gregsdart
Glad to hear you got it back, SG. May you have MANY FUN ROUNDS!
[Re: gregsdart]
#2348732
08/04/17 11:30 PM
08/04/17 11:30 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Awesome Greg. What block you running mate ?? Aftermarket or full fill ?
1963 Plymouth Max Wedge 1971 Barracuda
[Re: ozymaxwedge]
#2348775
08/05/17 01:27 AM
08/05/17 01:27 AM
gregsdart
Awesome Greg. What block you running mate ?? Aftermarket or full fill ? Mega block,4.500 bore, not filled. 4.15 stroke. 3065 race weight.
[Re: quickd100]
#2348776
08/05/17 01:29 AM
08/05/17 01:29 AM
gregsdart
Be careful about listening to the voices Greg. I listened to mine and you've seen what I ended up with! Say Hi to Sandy for me and Rocio. Dave Well, you listened to the right ones!
[Re: 80arrow]
#2348861
08/05/17 11:04 AM
08/05/17 11:04 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Great seeing you enjoying the car again and getting out making some hits. It may take us longer to get the job done but the fire is still in our belly.
[Re: gregsdart]
#2348925
08/05/17 12:58 PM
08/05/17 12:58 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Greg..... I hope this isn't like pouring salt on a wound...... But what was the combo you were running to get the times in your sig, and what do you think it would run now in similar air?
I know you were messing with cams/springs/rockers for a while...... Just wondering if in the end that ended up improving the combo or not. I lost track of all that stuff you changed.
[Re: gregsdart]
#2348979
08/05/17 02:39 PM
08/05/17 02:39 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
I firmly believe old racers never quite, we just figure out get more power out of the walker.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: fast68plymouth]
#2349093
08/05/17 06:05 PM
08/05/17 06:05 PM
gregsdart
I know you were messing with cams/springs/rockers for a while...... Just wondering if in the end that ended up improving the combo or not. I lost track of all that stuff you changed. No problem, Dwayne. There is so much different, it is hard to quantify, but I will try. All density altitudes come from Dragtimes web site. On the 8.779 pass, it went 153.16 mph, slight tail wind (5?) Cam- Isky RR735, 280/290/110,v in at 110. Jesel 1.55 rockers for .760 lift intake, .680+ exhaust. RADIAL slicks, that weigh 34 lbs each. They wouldn't 60 ft till I dropped them to 12 psi. Recommended, 14+ The car went into severe "radial rock", and I should have lifted. Guys asked me why I didn't! The converter was tighter than I thought, stalling to only 5300 plus. with 60 fts being 1.280 and slower, on that first pass, it could have run 8.760, as other runs showed 1.260 in worse weather. The next year I put new rings and bearings in it. Metal went through the motor and ruined the bearings. New cam also. .500 lobe lift intake, for .775 lift, .026 lash , .700 exhauast lift, duration 283/296/112, in at 110. The new cam didn't seem to pick up the power any, but who knows, it could have lost some power on the rebuild? Same converter, weight in race trim the same. 2006 the car got knew Goodyear 33.6 x 15.1 x 15 tires. Very heavy at 41 lbs each, and I am sure it dropped the trap rpm with growth and bigger diameter thrown in, not to mention resistance. The car ran 8.88 at 150.61 with 2124DA. I didn't run the car again till 2010. I had moved a lot of weight forward, and the car responded with consistent 1.260 60 fts. Also I had 2.30 intake valves put in, and flow picked up about 3-5 % on the intake, and the exhaust got sunk a touch to go down to a 1.78 but remained about the same flow numbers. The car ran 8.893 at 150 .13 mph, DA about 1249. I ran M5 fuel for 2011,12, and 2013, so those runs aren't really worth looking at. The car picked up about .13 ET in the 1/4. After the 2015 season I had the block rehoned, put in new rings, bearings, cam, and 1.7 rockers. The hone didn't remove all of the marks from alky corrosion, but I figure they didn't want to go too far with the same pistons. The crescent shaped marks are down the bore a ways, so maybe there is minimal loss, I don't know. The new cam is a Mike Jones inverted flank cam, 285/296/114 duration, with .016 lash. Lift is .867 intake, .750(?) exhaust, in at 108. I also had the converter loosened up to a true 6200 rpm flash stall. The car has run the numbers in the first post, with consistent 1.260 60 fts, 8.894 at 150.61, da2323. Tail wind, 5 to 7 mph. So all in all I am not impressed, but it may be that all the changes messed up a very good combo that I had back in 2003. I think I picked up some with the converter for sure, not sure on the cam. Like an idiot I sold that Isky cam. Wish I hadn't now!
[Re: gregsdart]
#2349130
08/05/17 07:30 PM
08/05/17 07:30 PM
fast68plymouth
So. Burlington, Vt.
I guess my impression of how I remembered it all went down was reasonably correct. A lot of time, effort and $$$ spent for a very minimal gain. I'm sure the radials were worth at least a tenth and a mph or two...... So youre kinda back where you were.
I think yours is a good example of...... It's not always as easy as people say it is to pick up a combo that's working pretty well. At least, not by "tweaking" it.
#2349142
08/05/17 08:31 PM
08/05/17 08:31 PM
gregsdart
I think yours is a good example of...... It's not always as easy as people say it is to pick up a combo that's working pretty well. At least, not by "tweaking" it. I think you are spot on. There is just no substitute for experience. I would venture to guess that your tunnel ram suggestion some time ago would have been a better move, and combine it with an offset crank grind to pick up 29 cubes (4.4 stroke vs 4.15) might have been a better move, plus some effort to lighten this tank up. At my age and being retired, this is what I have, so I will enjoy it as is, unless someone has a tunnel ram for sale dirt cheap
[Re: gregsdart]
#2349278
08/06/17 01:27 AM
08/06/17 01:27 AM
gregsdart
Thanks hardcore, and everybody else. When I enitialy built this motor most of the choices were a result of listening to sharp guys on this board. A lot of knowledge here. This also led me to go to (and listen to!) some very sharp folks for head porting and cam choice. The results speak for themselves. These heads are 1998 440-1 vintage, not as good as newer heads?
