BB Victor Heads Valley Cover(s) #2348389
08/04/17 12:33 PM
08/04/17 12:33 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Anyone have success using the stamped valley cover that Edelbrock offers for the BB Victor heads, or should I start saving my $$$ for AndyF's replacement cover?
I'm asking 'cuz I have the E part already, but the board member who purchased my Hughes CNC Victors told me that his leaked and he switched to the AR Engineering piece to correct the issue.
Re: BB Victor Heads Valley Cover(s) [Re: BradH] #2348394
08/04/17 12:44 PM
08/04/17 12:44 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Edelbrock 7798? I use one on my mud truck, so far after 3 years it has kept the oil in, the mud/water out.
Re: BB Victor Heads Valley Cover(s) [Re: CTD5.9] #2348398
08/04/17 12:48 PM
08/04/17 12:48 PM
BradH Offline OP
BradH  Offline OP
I don't know E's part #, but it's whatever they sell to use w/ Victor heads on an RB block.
Actually, I have two... but the first one wasn't drilled properly by Edelbrock. They sent me a replacement and let me keep the improperly manufactured one... as scrap metal? whistling
Re: BB Victor Heads Valley Cover(s) [Re: BradH] #2348403
08/04/17 01:03 PM
08/04/17 01:03 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Only valley pan I ever had an issue with was the 440 source piece that didn't seal to the heads correctly. They were flimsy and leaked in the middle.
The Edelbrock piece, that bolts directly to the head, sealed great and actually required a pry bar to disassemble.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: BB Victor Heads Valley Cover(s) [Re: BradH] #2348404
08/04/17 01:03 PM
08/04/17 01:03 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I think its this one: http://www.jegs.com/i/Edelbrock/350/7798/10002/-1 only one I can find. It's really nothing fancy but it does its job, not sure how it would leak unless not enough RTV was used. Maybe if the heads are milled and the bolts aren't in the right spot anymore.
Re: BB Victor Heads Valley Cover(s) [Re: BradH] #2348454
08/04/17 02:31 PM
08/04/17 02:31 PM
I bought and used the low deck valley pan cover on my bracket motor with the M.W victor heads, it has been on there for over three years of racing with no leaks work
I did use a liberal amount of Permatex grey adhesive silicone on the sides and ends up
I've had it off several times to grind on the heads for pushrod clearances when I switch to the Harland Sharp 1.6 ratio rockers from the original Hughes cyro treated set, no leaking any time with the grey silicone shruggy
Re: BB Victor Heads Valley Cover(s) [Re: BradH] #2348502
08/04/17 03:56 PM
08/04/17 03:56 PM
indy
E
eds dart Offline
eds dart  Offline
E
indy
i had no luck at all with Edelbrocks cover. It warped while i was installing it and leaked in use. I bought Andy F cover. works great. My Victors were milled some. maybe had something to do with the leaks. Andys cover fit perfect even with the minor milling my heads have.
Re: BB Victor Heads Valley Cover(s) [Re: eds dart] #2348524
08/04/17 04:37 PM
08/04/17 04:37 PM
BradH Offline OP
BradH  Offline OP
IIRC, my heads have been milled .030", so I don't know if that's enough to cause leaks. I'll look for fitment issues when I get a chance to mock up both heads on the block soon.
