70 Cuda Disc Brake Drag #2348110
08/03/17 08:53 PM
08/03/17 08:53 PM
Kingston, Ontario
70GranCoupe Offline OP
Kingston, Ontario
I have replaced my entire brake system from front to back and now have stock power front disc with drums on the back. When I apply the brakes the fronts will not release. I opened the caliper bleeder and it releases. So it is not the calipers. I cracked the lines on both sides of the metering valve and the proportioning valve and each one relieves the pressure on the wheels. So that rules out the valves. I cracked it at the master and that relieved the pressure, so thinking that maybe it was the master I replaced it, however no change. I then loosened the master from the booster and that did not make a difference. I checked the booster push rod and it is adjusted all the way in. So in my mind either the booster rod is incorrect or there is something mechanical in the pedal system that is not pulling back. Any thoughts. Thanks.
Re: 70 Cuda Disc Brake Drag [Re: 70GranCoupe] #2348113
08/03/17 09:01 PM
08/03/17 09:01 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Are you using a master for a front drum set up, or for a front disc set up? The master for drums have a valve in that port to keep the fluid in the line and wheel cylinders as the shoes wear, etc. The disc master doesn't have that valve. That residual pressure in the line will keep the disc pads applied.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 70 Cuda Disc Brake Drag [Re: amxautox] #2348116
08/03/17 09:06 PM
08/03/17 09:06 PM
amxautox Offline
amxautox  Offline
Also if you changed from front drums to disc, you have to get a proportional/equalizer blocks for the disc brakes.
Tom
author unknown
Re: 70 Cuda Disc Brake Drag [Re: amxautox] #2348117
08/03/17 09:16 PM
08/03/17 09:16 PM
Kingston, Ontario
Kingston, Ontario
The proportioning and metering block are for disc/drum as well as the master.
Re: 70 Cuda Disc Brake Drag [Re: 70GranCoupe] #2348119
08/03/17 09:26 PM
08/03/17 09:26 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Are you using a DRUM/DRUM master or DISC/DRUM master? if your using the original 4whl DRUM/DRUM master, #1 either install the correct DISC/DRUM master or remove the residual valve from the rearward port on the DRUM/DRUM master as that is most likely the cause of your residual front brake lock
Re: 70 Cuda Disc Brake Drag [Re: 70GranCoupe] #2348120
08/03/17 09:27 PM
08/03/17 09:27 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
What's the masters pn# or casting number?, or application you purchased it as
Re: 70 Cuda Disc Brake Drag [Re: 70GranCoupe] #2348122
08/03/17 09:31 PM
08/03/17 09:31 PM
take the fitting/line off of the rear master cyl bowl half for the discs & stick a drill bit into the brass cone in the MC port & you will feel the RPV if it has one (its just a piece of neoprene and a spring) & if so pull the cone & toss it. confirm that you have ~.020" clearance between the round pushrod nub end & the bottom of the piston recess which I'm thinking you adressed when you seperated/pulled the MC forward. All that is left is a prop valve or line blockage. EDIT or a booster or linkage problem under the dash issue.
Re: 70 Cuda Disc Brake Drag [Re: 70GranCoupe] #2348126
08/03/17 09:41 PM
08/03/17 09:41 PM
Kingston, Ontario
Kingston, Ontario
It is a disc/drum master cylinder. Raybestos MC36283.
I will check to see if the rear has a RPV and will swap out the prop valve tomorrow.
I am thinking that it is a booster/linkage problem under the dash. When the car is shut off and sits for awhile the pressure comes off of the calipers.
Appreciate the advice.
Re: 70 Cuda Disc Brake Drag [Re: 70GranCoupe] #2348129
08/03/17 09:44 PM
08/03/17 09:44 PM
Holler what it ends up being.
Re: 70 Cuda Disc Brake Drag [Re: 70GranCoupe] #2348134
08/03/17 09:48 PM
08/03/17 09:48 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Watch the Rammans video on youtube on testing brake boosters. Sounds like a popet valve inside.
Re: 70 Cuda Disc Brake Drag [Re: 70GranCoupe] #2348173
08/03/17 10:54 PM
08/03/17 10:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
doubt it's the booster
Don't be the exception.
Re: 70 Cuda Disc Brake Drag [Re: 70GranCoupe] #2348176
08/03/17 11:00 PM
08/03/17 11:00 PM
amxautox Offline
amxautox  Offline
And of course the front brake lines are attached to the rear port, and the rear brake lines are attached to the front port?
Tom
author unknown
Re: 70 Cuda Disc Brake Drag [Re: amxautox] #2355546
08/17/17 04:55 PM
08/17/17 04:55 PM
Kingston, Ontario
Kingston, Ontario
Thanks for everyone's comments, even though they were both new, it was either the proportioning or the metering valve that was gone. I replaced both and everything now works. New question: now that I have connected the brake lines to the valve I get a constant slow seeping of fluid. Not a lot but it drips over time. I have tightened them down but no luck stopping it. Lines are new and are the stainless steel type. They do not seem to be seating properly. Any suggestions? Thanks.
Re: 70 Cuda Disc Brake Drag [Re: 70GranCoupe] #2355549
08/17/17 05:02 PM
08/17/17 05:02 PM
GA
roadrunninMark Offline
GA
You can get some thread sealer that is specifically made for brake fluid. Coat the the threads and reinstall. I've used it at all connections and no leaks.
Re: 70 Cuda Disc Brake Drag [Re: 70GranCoupe] #2355602
08/17/17 06:27 PM
08/17/17 06:27 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Loosen and retighten. SS lines seem to need that .
Re: 70 Cuda Disc Brake Drag [Re: 70GranCoupe] #2355634
08/17/17 08:03 PM
08/17/17 08:03 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Stainless threads can gall easily, use the proper TUBE wrench so as to not EGG the flare nut, use some grease or teflon paste to lube the threads so that you can tighten properly and seat the flare nut fully, once you gall the threads or EGG the flare nut using a regular wrench it tough to properly seat the flare tightly
Re: 70 Cuda Disc Brake Drag [Re: DAYCLONA] #2355912
08/18/17 08:54 AM
08/18/17 08:54 AM
Kingston, Ontario
Kingston, Ontario
Thanks again I will try all of the above.
