Re: world power systems sm. block distributor Rock Auto
[Re: can.al]
#2348125
08/03/17 09:41 PM
08/03/17 09:41 PM
RapidRobert
I didn't go to their site to check it but just me I would suggest a 70's OE electronic dist & the FBO $22 plate to set the mech amt where you want it & you can dial in the initial the springs & the can & reduce lower shaft axial play, reduce rotor tip clearance & check rotor phasing
[Re: can.al]
#2348146
08/03/17 10:09 PM
08/03/17 10:09 PM
RapidRobert
I'll go there sometime & check it out.
[Re: can.al]
#2355542
08/17/17 04:45 PM
08/17/17 04:45 PM
Posts: 1,274 Ontario.Canada
can.al
Ontario.Canada
..finally tested the distributor.Initial was 15 and by 2000 there was about 22 degrees advance having full advance of 35 degrees around 3600 rpm. ( Initial plus mechanical )This is a very slow curve and would be very helpful if you're fighting detonation in a high compression sm block.Single stage springs are loaded initially and adding 1 weak spring should work great for a street machine to bring advance in quicker. no welding of slots etc.
