Re: Fuel filter
[Re: 70duster340]
#2347029
08/01/17 11:59 PM
08/01/17 11:59 PM
70duster340
Re: Fuel filter
[Re: 70duster340]
#2347084
08/02/17 01:30 AM
08/02/17 01:30 AM
RapidRobert
I'd suggest a good 10 micron high flow filter between the mech pump & the carb (like OE). I read a copy of the Don Dulmage "tuning to win" FBO booklet (I wouldn't buy it) & he says alot of filters are junk. Russell or other name brand would be my choice (& the right one of theirs).
Re: Fuel filter
[Re: 70duster340]
#2347107
08/02/17 02:23 AM
08/02/17 02:23 AM
70duster340
Re: Fuel filter
[Re: 70duster340]
#2347505
08/02/17 10:09 PM
08/02/17 10:09 PM
Posts: 732 Michigan
BlueRacer69
Excellent info. What filter would you recommend? A Napa Gold Fuel Filter with 5/16 inlet & outlet would be a good chose.
Re: Fuel filter
[Re: BlueRacer69]
#2347922
08/03/17 03:11 PM
08/03/17 03:11 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
Excellent info. What filter would you recommend? A Napa Gold Fuel Filter with 5/16 inlet & outlet would be a good chose. No glass or plastic filters would be my recommendation.. I ran two filters right after my resto was done.. I removed the " tank to fuel pump" filter later on and now just have the stock metal filter behind the alternator...
Re: Fuel filter
[Re: floridian]
#2347995
08/03/17 04:52 PM
08/03/17 04:52 PM
Posts: 732 Michigan
BlueRacer69
Excellent info. What filter would you recommend? A Napa Gold Fuel Filter with 5/16 inlet & outlet would be a good chose. No glass or plastic filters would be my recommendation.. I ran two filters right after my resto was done.. I removed the " tank to fuel pump" filter later on and now just have the stock metal filter behind the alternator... If the OP is against plastic filters then I will also suggest a Wix #33012 metal filter. Cost is around $5 buck. But I've run Napa's gold plastic fuel filter for years without issues. I guess it's just a matter of personal preference.
