Re: 1992 Dodge Dakota 5.2 Magnum help and suggestions!!!
[Re: 318MAGNUM]
#2346579
08/01/17 09:35 AM
08/01/17 09:35 AM
Posts: 20,646 in a cattle trailer down by th...
Guitar Jones
You didn't say how many miles on it, anything else wrong with it? Any and all information is important when diagnosing a problem.
Just an FYI, those trucks have a fuel filter on the frame rail. If it's been plugged for awhile it will take out the pump.
[Re: 318MAGNUM]
#2347328
08/02/17 02:58 PM
08/02/17 02:58 PM
Posts: 684 Maine
jerseybud
Maine
check for codes and check fuel pressure first and second. I would get it running properly before thinking about mods. The 92-93 dakota/ram had some unique things about them like the big bore exhaust manifolds and its been said the cam and torque convertor were tweaked those years as well.
Some common 5.2/5.9 magnum issues to check: plenum plate EGR spark plug wire routing wiring splice corrosion under fuse box on 92-95 dakotas
If your exhaust leak is before the oxygen sensor, gotta fix that first. I have a collection of dakota y pipes if you want one. Dual exhaust kinda tight in that chassis
[Re: DaytonaTurbo]
#2393841
10/27/17 03:23 PM
10/27/17 03:23 PM
Posts: 21 da' 'BURGH
The War Wagon
da' 'BURGH
I have duals on my 5.2. I went with 2.25", no X or H. Thrush turbo mufflers were cheap at summit, they are too quiet. I went true duals on my '92 Magnum RC - I went Magnaflow glasspacks, and they snap crackle and pop like a MUTHA when coasting down a hill with 4.56 gears! I also have the performance ECU for the OBD-1 Magnum engine, if the OP is interested. Gotta run premium fuel with it, though.
- 1992 Dodge Ramcharger LE: a work in progress... -
