73/74 Roadrunner questions
#2345826
07/30/17 06:48 PM
07/30/17 06:48 PM
Posts: 1,947 SINY
SanityLost
SINY
First question is about the roof stripes, 73 have the strobe stripe and I have seen some 74's with a solid stripe over the roof is this a 74 only thing? Next question is about the rally instrument cluster bezel, what is the difference between the 71-73 bezel to the 74 bezel? And lastly the speedo, should it be a 150mph or 120 mph speedometer? And auto trans console, tShift slap stik or Ball shifter handle?
Re: 73/74 Roadrunner questions
[Re: SanityLost]
#2346120
07/31/17 10:57 AM
07/31/17 10:57 AM
DaytonaTurbo
Manitoba, Canada
First question is about the roof stripes, 73 have the strobe stripe and I have seen some 74's with a solid stripe over the roof is this a 74 only thing? Next question is about the rally instrument cluster bezel, what is the difference between the 71-73 bezel to the 74 bezel? And lastly the speedo, should it be a 150mph or 120 mph speedometer? And auto trans console, tShift slap stik or Ball shifter handle? The solid stripe was a 74 thing, as was the little icons beside the headlight and wiper switches. Physically they interchange with 71-73. My 73 satellite parts car was built with a rallye dash with the 120mph speedo and no tach. Did the tach option get you the 150 speedo? Slapstick should be a t handle.
