Aftermarket Gauge Question #2345455
07/29/17 10:19 PM
07/29/17 10:19 PM
Rochester, New York
GregY Online content OP
GregY  Online Content OP
Rochester, New York
Hi All,
I am installing a set of aftermarket oil pressure, temp, and voltage gauges in a '71 Charger.
What is the proper way to tie the lights for the gauges into the electrical system?
Right now the wire for the light on my tach is just pinched in with a fuse in the fuse block, I know that is not the right way, and I want these gauges to be done correctly.
All advice is appreciated.
Greg
Re: Aftermarket Gauge Question [Re: GregY] #2345460
07/29/17 10:26 PM
07/29/17 10:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The orange wire is what feed the stock dash and radio lights. I'd tie into that, probably at the radio connection.
Don't be the exception.
Re: Aftermarket Gauge Question [Re: GregY] #2345739
07/30/17 03:26 PM
07/30/17 03:26 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Not only will it give your gauge lights when your dash lights are on, it will be dimmable.
Re: Aftermarket Gauge Question [Re: Magnum] #2345862
07/30/17 08:05 PM
07/30/17 08:05 PM
Rochester, New York
Rochester, New York
Thank you, I will look into doing it that way!
