Glass to Metal Washers (E-body Side Glass) - What to use? #2345705
07/30/17 02:18 PM
07/30/17 02:18 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
The hardware kit I purchased did not include these composite washers that go between the glass and the metal washers/nuts. I would like to find something local that will be sufficient and am wondering what you have used for these?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Glass to Metal Washers (E-body Side Glass) - What to use? [Re: GoodysGotaCuda] #2346139
07/31/17 11:42 AM
07/31/17 11:42 AM
moparx Offline
moparx  Offline
how about a fiber type washer sourced at the local hardware store ? my local ACE hardware [only down the block from my house up] has quite a few of these in different sizes and thicknesses. only cost a pittance. might be something to consider.
beer
Re: Glass to Metal Washers (E-body Side Glass) - What to use? [Re: GoodysGotaCuda] #2346188
07/31/17 01:30 PM
07/31/17 01:30 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Almost looks like the leather washer for the starter drive would work. Not sure how easy they are to get local.
Re: Glass to Metal Washers (E-body Side Glass) - What to use? [Re: GoodysGotaCuda] #2346244
07/31/17 03:48 PM
07/31/17 03:48 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Re: Glass to Metal Washers (E-body Side Glass) - What to use? [Re: CSK] #2346606
08/01/17 10:42 AM
08/01/17 10:42 AM
moparx Offline
moparx  Offline
Originally Posted By csk
those look like some of the selection at the hardware store. wonder what they are made of ?
beer
Re: Glass to Metal Washers (E-body Side Glass) - What to use? [Re: GoodysGotaCuda] #2346847
08/01/17 07:32 PM
08/01/17 07:32 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Make your own from gasket material
