Re: Use the rubber bands with slider calipers or not?
[Re: 68_661charger]
#2345113
07/29/17 04:17 AM
07/29/17 04:17 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Have owned several 72-93 trucks with slider calipers and the only one that needed the bands was my 92 D350. Going down the road the calipers would clatter around when going over little bumps and ripples in the road. Real annoying. The band circles the mount so part of it is in the slide area between the mount and caliper. They would last for a few thousand hwy miles before wearing off and the caliper would clatter again. Use caliper lube on the contact areas between the caliper and its mount that it slides in. Then drive it. If no clatter then toss the bands.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: 68_661charger]
#2345645
07/30/17 11:49 AM
07/30/17 11:49 AM
Posts: 1,767 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Agree, especially with moparmarks...I installed them on my coupe, care has barely any miles of the few seasons now (3k), at the start of this season I did a full "check-up", bleed the brakes, adjust, etc...sure enough, the rubber bands broke...I removed them, the brakes are quiet, but in my install I used the synthetic grease on all moving parts anyways.
