Use the rubber bands with slider calipers or not? #2345098
07/29/17 01:47 AM
07/29/17 01:47 AM
Indiana
68_661charger Offline OP
Indiana
77 Dodge truck. I googled this and still not sure where they go. It says put em around the caliper adapter. Then what? Anybody have a clear installed picture? Do I even need them? Thanks in advance.
Re: Use the rubber bands with slider calipers or not? [Re: 68_661charger] #2345100
07/29/17 01:51 AM
07/29/17 01:51 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I've never used them and have no idea how they go on.
Re: Use the rubber bands with slider calipers or not? [Re: 68_661charger] #2345102
07/29/17 01:56 AM
07/29/17 01:56 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Originally Posted By paironines
.....Do I even need them? Thanks in advance.
No iagree
Re: Use the rubber bands with slider calipers or not? [Re: 68_661charger] #2345112
07/29/17 04:05 AM
07/29/17 04:05 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I found them under the spring type hold down retainer.
Re: Use the rubber bands with slider calipers or not? [Re: 68_661charger] #2345113
07/29/17 04:17 AM
07/29/17 04:17 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Have owned several 72-93 trucks with slider calipers and the only one that needed the bands was my 92 D350. Going down the road the calipers would clatter around when going over little bumps and ripples in the road. Real annoying. The band circles the mount so part of it is in the slide area between the mount and caliper. They would last for a few thousand hwy miles before wearing off and the caliper would clatter again.
Use caliper lube on the contact areas between the caliper and its mount that it slides in. Then drive it. If no clatter then toss the bands.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Use the rubber bands with slider calipers or not? [Re: 68_661charger] #2345134
07/29/17 09:18 AM
07/29/17 09:18 AM
Indiana
Indiana
Sounds good guys. Thank you.
Re: Use the rubber bands with slider calipers or not? [Re: 68_661charger] #2345645
07/30/17 11:49 AM
07/30/17 11:49 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Agree, especially with moparmarks...I installed them on my coupe, care has barely any miles of the few seasons now (3k), at the start of this season I did a full "check-up", bleed the brakes, adjust, etc...sure enough, the rubber bands broke...I removed them, the brakes are quiet, but in my install I used the synthetic grease on all moving parts anyways.
