440 vs. 522 RB Engine Recommendations #2345211
07/29/17 12:50 PM
07/29/17 12:50 PM
doubleyellow Offline OP
Was investigating buying a turn-key motor from Carolina Machine Engines. I'm sure there are hundreds of pluses and minuses, but anyone have advice on which engine to go with for a street cruiser with a bit more power than pure stock?
Will be in a 1970 Challenger convertible
Comments on:
- fuel consumption between the 440 and 522?
- worth the extra money for the 522 stroker - really an improvement on torque?
- enough vacuum for brake booster?
- Would you run stock exhaust, or must run headers to get the power increase? What tube size?
- Other suggestions?
Re: 440 vs. 522 RB Engine Recommendations [Re: doubleyellow] #2345218
07/29/17 12:57 PM
07/29/17 12:57 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
522 will make more torque and at a lower rpm. If you can swing it I would go for it.
Fuel consumption, all else being equal (cam, heads, intake) mpg will be close, maybe 2mpg difference. But usually with a stroker comes a bigger cam, quite possibly better flowing heads and more fuel being blown out the tail pipe.
For a given cam, a 522 will make more vacuum than a 440.
I would run headers, they make more power, size would be dictated by your cam/head choices. For a 440 I would probably do 1-7/8 tubes and 2" for the 522. You can run manifolds but you will give up some power and cam choices to run best with manifolds are much more sensitive.
For a street cruiser rag top challenger, a stock stroke 440 will make all the power you want, but if the cost difference is close why not spring for the extra cubes!
Re: 440 vs. 522 RB Engine Recommendations [Re: doubleyellow] #2345234
07/29/17 01:17 PM
07/29/17 01:17 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You really do not give enough information for a valid comment on either engine.
But I will say this, fuel consumption and an RB are like water and oil, it'll suck regardless of which one you chose.
Carolina Machine Engines lists 5 different 440's and 4 different 522's.
Don't be the exception.
Re: 440 vs. 522 RB Engine Recommendations [Re: doubleyellow] #2345261
07/29/17 01:47 PM
07/29/17 01:47 PM
how much are they wanting for em? I've thought about the 440source 543 rotating assy but not sure if 100 extra cubes is worth $2250 (definitely not at the moment).
Re: 440 vs. 522 RB Engine Recommendations [Re: doubleyellow] #2345265
07/29/17 01:52 PM
07/29/17 01:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Re: 440 vs. 522 RB Engine Recommendations [Re: doubleyellow] #2345269
07/29/17 01:56 PM
07/29/17 01:56 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
My first question would be what are your intentions and do you really need a 522 ?
Re: 440 vs. 522 RB Engine Recommendations [Re: doubleyellow] #2345274
07/29/17 02:05 PM
07/29/17 02:05 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
You have a convertible so I doubt you are building a drag strip terror and even with subframe connectors you have to think about tearing up the body. A 440 incher can easily get your car into the 11's at the track. The 522 will use more fuel unless you baby cam it and gear it really high, that's the reality of it. I also see stock exhaust as a cork in a stroker.
The 440 is really a great package in stock or lightly modified form. If you stroke it you will also want to buy aftermarket heads etc. to match everything up.
I've run 426 Hemis for years and with their huge heads the stroker is the missing link in making them a great package, 440 doesn't need the extra inches to be a balanced package, it is already.
Sheldon
Re: 440 vs. 522 RB Engine Recommendations [Re: doubleyellow] #2345291
07/29/17 02:58 PM
07/29/17 02:58 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Go big now and you won't regret it later.
Re: 440 vs. 522 RB Engine Recommendations [Re: bobby66] #2345333
07/29/17 04:52 PM
07/29/17 04:52 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
THIS ^^^^
Re: 440 vs. 522 RB Engine Recommendations [Re: doubleyellow] #2345393
07/29/17 07:25 PM
07/29/17 07:25 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I can tell you this and that is my 493 eats alot more fuel then my old 440 did. Course it has a bigger cam and better heads but I do use the same carb on it. I had to jet up the carb alot also. Ron
Re: 440 vs. 522 RB Engine Recommendations [Re: doubleyellow] #2345421
07/29/17 08:44 PM
07/29/17 08:44 PM
To be more specific, was looking at their 440 Lopey or 522 Lopey to be sure I have enough vacuum for the brakes....please keep the recommendations coming......
Re: 440 vs. 522 RB Engine Recommendations [Re: doubleyellow] #2345426
07/29/17 08:50 PM
07/29/17 08:50 PM
I don't really "NEED" a 522, but since it's been off the road for 30 years, I don't want to be disappointed with "just" 420 HP +/-. Don't want to tear the convertible in half though.
Is 500 HP in an E-body convertible overkill for street cruising and flooring it occasionally, or is it too much?
Car came stock with 440, 4-speed and Dana rear (3.54 ratio)
Re: 440 vs. 522 RB Engine Recommendations [Re: doubleyellow] #2345429
07/29/17 09:11 PM
07/29/17 09:11 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
It will be a BLAST!!!
Re: 440 vs. 522 RB Engine Recommendations [Re: CSK] #2345533
07/30/17 01:23 AM
07/30/17 01:23 AM
there's no such thing as overkill! Go big right now. EDIT you can build up or detune as needed later but get the cubes in there right now to have that potential at your disposal.
Re: 440 vs. 522 RB Engine Recommendations [Re: doubleyellow] #2346142
07/31/17 11:54 AM
07/31/17 11:54 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Sounds like what you want is a nice street cruiser. Build the 522. It doesn't need to be a Max effort build. What the additional stroke is going to do is give you a broad flat torque curve. This is what you're after in a ballsy street cruiser. I built a 512 just a couple months ago and kept it mild, but it pulls like a freight train all the way through. Go big now. You won't regret it.
