273 In a 1964 Dodge Polara?
#2345130
07/29/17 08:51 AM
07/29/17 08:51 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
I have owned a lot of Mopars in the last 30 years or so and have come across a car one of my relatives that has passed has left me. They were the original owners and the car only has 40 k on the obdometer. I am trying to find out why this car has a 273 2bbl that did not seem to be offered as an option. I have had several other enthusiasts inform me that there is no way this combination was available as this was the first year the 273 was offerd and it was mostly put in Darts. Without a serial number to confirm this on the engine block and the build sheet being lost when the back seat was redone back in the 70s because of a cigarette being thrown out the window and ending up burning a huge hole in the seat. Is there any other way to assure my fellow enthusiasts that this weird combo is indeed from the factory?
Thanks in advance!
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: 273 In a 1964 Dodge Polara?
[Re: BB65Barracuda]
#2345135
07/29/17 09:27 AM
07/29/17 09:27 AM
Posts: 1,606 Pgh, PA
Bull1tt
Pgh, PA
I'm gonna say someone put that engine in that car for whatever reason. Dealer/mechanic yes, factory, prob not... Once, I bought a car from a relative, a 71 Monte Carlo. Went to auto parts and bought all the standard tuneup parts. Points, plugs, cap, etc. Drive to work next day and started to run rough, barely made it home with one heck of a noise under hood. Two plugs blew out of heads, couple more were loose. Ends up that the plugs I put in were tapered style, but the old ones had washers. 71 first year for tapered plugs. Eventually found out my long block had been replaced for a mechanical issue. They thought the dealer just fixed the original engine when I talked to them. They weren't sure what was the problem originally, but dealer did fix it and it was fine afterwards.
[Re: Rhinodart]
#2345441
07/29/17 09:42 PM
07/29/17 09:42 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
The car was owned by a relative and purchased from the dealership new and they had all of the records for service since new. No way to actually prove if this 1964 273 came in the vehicle? The VIN or the Fender tag do not show the motor info from what I can tell looking on the standard sites. You positive there is no way this is the engine that came from the factory? I've asked a few of the elder relatives and they are sure the way Gramps took care of the car that if the motor had blown he would have been devastated and they would have heard all about it. The car is pretty nice, the old guy took care of it. I'm going to have to change my vehicle discriptions if I can't find a way to support the numbers matching claim. I had n idea this was such an odd ball set up.
[Re: njk53]
#2346239
07/31/17 03:42 PM
07/31/17 03:42 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
& 360s were introduced on a limited number of '70 vehicles & 400s were introduced on a limited number of '71 vehicles so, without more information/documentation & follow-up by the OP "WE" can't help
