Re: Weird MoPar interchangability.....
[Re: NachoRT74]
#23436
12/05/09 01:31 PM
12/05/09 01:31 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
The speed-warning device in the passenger seat of a 70 'Cuda telling the driver to slow down can be installed in other cars with the exact same functionality.
didn't know about that option exist
You're obviously not married....
[Re: NachoRT74]
#23439
12/05/09 06:59 PM
12/05/09 06:59 PM
Posts: 5,285 South Carolina
FM3_1970
South Carolina
LOL... not, and not even living in USA. beside that E bodies weren't assemblied down here. How is coded on tag/buildsheet ?
That would be MRS. For export to Latin America, SRA.
[Re: FM3_1970]
#23440
12/05/09 11:20 PM
12/05/09 11:20 PM
Posts: 301 wisconsin
swifter
wisconsin
Here is a good one and when you think about it someone knew we were going to do this--A 70 A833 with smallblock bell housing will bolt right up to a 2006 5.7 Hemi and will go right in to a 70 Duster--Just finished this & It still freaks me out that this was a NO-SWEAT install--Swifter
2007 Ram 2500 Cummins
2008 Dodge Nitro
1970 340 Valiant Duster
[Re: Greg55_99]
#23442
12/06/09 01:18 AM
12/06/09 01:18 AM
Posts: 1,806 Newfoundland Canada
Mopar1
Newfoundland Canada
Ummm.... Bellhousing from 96-00 2.5L Dakota fits Chevrolet LS4....
Ok, I'm done...
Greg
I'm not suprised considering GM has manufactured a lot of transmissions for Chrysler.
[Re: buildanother]
#23446
12/06/09 08:21 PM
12/06/09 08:21 PM
Posts: 2,177 ill
dennismopar73
ill
yes they do perfectly as a matter of fact!!! just gives you a wing window!!
[Re: JonC]
#23451
12/06/09 09:35 PM
12/06/09 09:35 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
.040 over 360 file fit piston rings are the same as standard 340 rings only a LOT cheaper.
I have non file fit 350 Chevy rings in my .040 360.
[Re: Mopar1]
#23453
12/06/09 10:01 PM
12/06/09 10:01 PM
Posts: 4,587 St. John's Newfoundland
440newport
Such as?
I figure it's the other way around... New Process(Chrysler) made transfer cases for all the big 3 and then some, there was also a version of the OD 833 in Chevies known as the MY6.
