Carter carb kits #2344935
07/28/17 06:00 PM
07/28/17 06:00 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Where is the best place to get the best kit of a 70 carter carb for a 440? I had a place saved on my phone and it lost it when it crashed. Seems this guy specialized in carter four barrel carbs.
Re: Carter carb kits [Re: fastmark] #2344941
07/28/17 06:11 PM
07/28/17 06:11 PM
"The carb shop" in Eldon Missouri. (Google it).
Re: Carter carb kits [Re: fastmark] #2345010
07/28/17 09:02 PM
07/28/17 09:02 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
The carburetor doctor :
http://www.carbkitsource.com/
Cheers
Re: Carter carb kits [Re: fastmark] #2345051
07/28/17 10:49 PM
07/28/17 10:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Carter carb kits [Re: Supercuda] #2346271
07/31/17 04:51 PM
07/31/17 04:51 PM
dogdays Offline
dogdays  Offline
How about using an Edelbrock kit? I bought a NORS AVS 4966. It had sat so long that the accelerator pump wouldn't work. My carb is a minority accelerator pump diameter.
R.
Re: Carter carb kits [Re: fastmark] #2346359
07/31/17 08:26 PM
07/31/17 08:26 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You'll do as well here as anywhere,complete kits or just what you need.
https://quadrajetparts.com/afb-avs-carburetor-rebuild-kits-c-299_130_151.html
