Re: Dropped the *!:*;#* wrench
[Re: 62maxwgn]
#2344381
07/27/17 04:14 PM
07/27/17 04:14 PM
Posts: 20,669 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Years ago I dropped a bolt behind in the kick panel area on my car. I tied a magnet to the middle of a piece of string and pulled the string thru and the magnet grabbed the bolt and pulled it up after a few tries. No way was I going to leave it in there. Maybe you can feed a string from one of the drain slots up high?
If you have a farmers supply place around you can get a cow magnet and put it on the end of a wood dowel using a chunk of rubber hose. Cow magnets are narrow and can fit into tight spaces.
[Re: maximus]
#2344739
07/28/17 10:39 AM
07/28/17 10:39 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I have found that a bore scope is a handy tool for retrieving dropped treasurers.
Have a great day Iowan
"obsolete is neat"
[Re: maximus]
#2344796
07/28/17 12:45 PM
07/28/17 12:45 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Need to see the full picture of the exact situation to get a good idea, however something comes to mind!
The spray in foam idea can be somehow good, not to let it there, but fill all around the wrench ( on bottom better then on top) like a cast, with a wire inserted, then once dried pull out the wire to pull put the cast foam piece build with the wrench in it. The wire needs to be with a bent shape to be sure won't slide off the foam... maybe parallel to the wrench witn several bents.
Some light oil on rocker and quarter panel walls will help the foam to not stick to them.
Maybe sounds crazy but... who knows!
[Re: hemirdrnnr]
#2344894
07/28/17 04:02 PM
07/28/17 04:02 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Get a stick chew some gum when it gets sticky put it on the wrench and pull it out, ha if it works for monkeys why not moparts members! HTH let Wile E. Coyote in?
[Re: maximus]
#2345162
07/29/17 11:11 AM
07/29/17 11:11 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
you can buy a borescope at HF for about $60. once you know exactly where it is, removing it will be much easier.
i bought one to verify a coolant leak in my Department Of Boost custom intake manifold for my mustang. they work pretty good, run on 4 AA batteries.
perception is 90% of reality
[Re: BDW]
#2345163
07/29/17 11:15 AM
07/29/17 11:15 AM
Supercuda
About to go away
About to go away
up yours
That's the problem, I will know.
Exactly
[Re: Supercuda]
#2345197
07/29/17 12:19 PM
07/29/17 12:19 PM
NachoRT74
Valencia, España
Exactly
[Re: BDW]
#2345202
07/29/17 12:29 PM
07/29/17 12:29 PM
RapidRobert
Wife told me not to worry, Listen to the wife & if that wont work then yes purchase a rotisserie, ain't nothing you have tried so far has worked so its gonna have to be turned upside down. When you hear that wrench hit the cement floor you will be so relieved. We're pullin for ya!
