Re: Sleeving Rare Blocks Back to Standard Bore
[Re: RestoreCuda]
#2342235
07/24/17 12:46 AM
07/24/17 12:46 AM
Posts: 43,308 Bend,OR USA
Cab_Burge
I sold a 428 Ford FE block to Donny Keene after he won the NHRA stock world championship, I've known him and his father a long time. A friend of mine had two of them and wasn't going to use both of them so I told Donny about them and he ask me to see if I could get one for him, I have a Dakota 1000 sonic tester and I asked him if he wanted to pay me to sonic test both of them to get the best one and he said yes. I ask what was the least he wanted in cylinder wall thickness and he said anything above .090 unbored was good ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) He did say he always sleeves all eight cylinder with ductile iron sleeves before building any of his race motors for his NHRA Stocker ![work work](/ubbthreads/images/graemlins/custom/work.gif) I know several other southern CA NHRA 340 Stocker racers that do the same thing The key to success is having that kind of work done is by having a good Hi Po machine shop do all of it ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) good luck, let us know what you do and the results
[Re: RestoreCuda]
#2343883
07/26/17 08:38 PM
07/26/17 08:38 PM
crabman173
crabman173
It is a PIA on one hand but...it can work beautifully Old nascar 348's were awful cores from factory Jr Johnsons guys sleeved them and kept on trucking I have done it several times all with fine results--once it has been done right--correct fit--plate honed--it is good to go IMO
[Re: RBRE]
#2344325
07/27/17 02:05 PM
07/27/17 02:05 PM
Posts: 1,237 North Central, Indiana
Roughbird72
We have done it for years. Doing a Hemi right now dated Oct 11, 1963! We always bore one cylinder on one bank and then one on the other. Then we install the sleeves. Then do two more on opposite banks. Some shops just bore out all 4 or 8 and then bang them all in which really pushes the block around. We also never do 2 cylinders side by side. If you start with a center cylinder you can then move to the far end cylinder then go to the opposite end cylinder and then the other center and never do two side by side. Same with honing. Also, we always use dry ice or liquid nitrogen to drop the sleeves in without banging on them. You always need to align hone afterwards. -- Ray Good to know ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
72 Plymouth Roadrunner 11.08@123.25
[Re: RestoreCuda]
#2344444
07/27/17 06:58 PM
07/27/17 06:58 PM
Posts: 4,213 New York
polyspheric
New York
Draw no conclusions such as "If someone did this to engine A, I can do it to engine B".
Boffin Emeritus
[Re: RBRE]
#2344693
07/28/17 04:38 AM
07/28/17 04:38 AM
Posts: 81 Sweden
MikeN
Sweden
We have done it for years. Doing a Hemi right now dated Oct 11, 1963! We always bore one cylinder on one bank and then one on the other. Then we install the sleeves. Then do two more on opposite banks. Some shops just bore out all 4 or 8 and then bang them all in which really pushes the block around. We also never do 2 cylinders side by side. If you start with a center cylinder you can then move to the far end cylinder then go to the opposite end cylinder and then the other center and never do two side by side. Same with honing. Also, we always use dry ice or liquid nitrogen to drop the sleeves in without banging on them. You always need to align hone afterwards. -- Ray Very interesting! And good for a customer who has bought a sleeved block from you to know. But is/was the World aluminum block done with the same care? Or the Chevrolet LS7 for that matter. Both had interference type liners and sold in large numbers. And aluminum is more flexible than iron. Is there a (cost saving) way to get around this routine?
[Re: RBRE]
#2344851
07/28/17 02:50 PM
07/28/17 02:50 PM
Posts: 4,255 Canada
WO23Coronet
Canada
We have done it for years. Doing a Hemi right now dated Oct 11, 1963! We always bore one cylinder on one bank and then one on the other. Then we install the sleeves. Then do two more on opposite banks. Some shops just bore out all 4 or 8 and then bang them all in which really pushes the block around. We also never do 2 cylinders side by side. If you start with a center cylinder you can then move to the far end cylinder then go to the opposite end cylinder and then the other center and never do two side by side. Same with honing. Also, we always use dry ice or liquid nitrogen to drop the sleeves in without banging on them. You always need to align hone afterwards. -- Ray Do you guys ever heat them up after the sleeves are installed to stress relieve them? How much interference fit do you use?
[Re: MikeN]
#2344923
07/28/17 05:27 PM
07/28/17 05:27 PM
Posts: 22 PA
RBRE
PA
We have done it for years. Doing a Hemi right now dated Oct 11, 1963! We always bore one cylinder on one bank and then one on the other. Then we install the sleeves. Then do two more on opposite banks. Some shops just bore out all 4 or 8 and then bang them all in which really pushes the block around. We also never do 2 cylinders side by side. If you start with a center cylinder you can then move to the far end cylinder then go to the opposite end cylinder and then the other center and never do two side by side. Same with honing. Also, we always use dry ice or liquid nitrogen to drop the sleeves in without banging on them. You always need to align hone afterwards. -- Ray Very interesting! And good for a customer who has bought a sleeved block from you to know. But is/was the World aluminum block done with the same care? Or the Chevrolet LS7 for that matter. Both had interference type liners and sold in large numbers. And aluminum is more flexible than iron. Is there a (cost saving) way to get around this routine? Mike N: My apologies, I thought this thread was about trying to save rare cast iron blocks that never had removable sleeves. The method I suggested was just my opinion and doesn't mean its the best way. This method does put the least stress on the block and keeps the structural integrity from being compromised. As far as cost savings, I guess you could go to some caveman and do it a different way.
[Re: RBRE]
#2345178
07/29/17 11:50 AM
07/29/17 11:50 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
We have done it for years. Doing a Hemi right now dated Oct 11, 1963! We always bore one cylinder on one bank and then one on the other. Then we install the sleeves. Then do two more on opposite banks. Some shops just bore out all 4 or 8 and then bang them all in which really pushes the block around. We also never do 2 cylinders side by side. If you start with a center cylinder you can then move to the far end cylinder then go to the opposite end cylinder and then the other center and never do two side by side. Same with honing. Also, we always use dry ice or liquid nitrogen to drop the sleeves in without banging on them. You always need to align hone afterwards. -- Ray That's the right way. Shops I've used have been sleeving this way too, including using liquid nitrogen. Sleeves will be stronger (less wall flex) and sleeving lets you correct the factory placement and angle.
