what fuel??? #234431
02/24/09 12:16 AM
02/24/09 12:16 AM
MO
P
psycho_440 Offline OP
P
MO
a while back i had posted about "sneaking" race fuel and got my but chewed...well the new rules came out this year and looks like race gas is a go. when i talked to the guy in charge he said "everybody is running it anyhow". so my question is what do you all recommend?? seems like there are 100 different types. engine is a single carb 446 with iron heads and 11:1 CR.
Re: what fuel??? [Re: psycho_440] #234432
02/24/09 01:01 AM
02/24/09 01:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Since I ragged on you about it, I'll say... dont use
any more octane than is need to fend of detonation,
you dont need much but you WONT need more than a 100
EDIT
buy a brand that you can get easy around your place,
I havent seen much difference in brands but I use to
buy Torco alot
Re: what fuel??? [Re: MR_P_BODY] #234433
02/24/09 01:18 AM
02/24/09 01:18 AM
MO
P
P
MO
thanx that is the answer i was looking for. i will try to stay with the closest 100 octane i can find.
Re: what fuel??? [Re: psycho_440] #234434
02/24/09 01:21 AM
02/24/09 01:21 AM
MO
P
P
MO
the only other question i had was what if i used 110 or 112 and mixed it with pump 93 to save on cost?? wouldnt a 1:1 mix give me 100 or 102??
Re: what fuel??? [Re: psycho_440] #234435
02/24/09 01:36 AM
02/24/09 01:36 AM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
It doesn't work like that. Different specific gravity. Don't mix fuel if you can help it.
Re: what fuel??? [Re: Lil Demon] #234436
02/24/09 01:39 AM
02/24/09 01:39 AM
MO
P
P
MO
again thanx.. looks like 100 octane for me. glad regular fuel has gone down.
Re: what fuel??? [Re: psycho_440] #234437
02/24/09 01:55 AM
02/24/09 01:55 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Check out this site. You can get a lot of good info. There also a tech line you can call to get info on right octane for your application, mixing, etc.
Rockett Brand race fuel
