"Clean neutral" Why?
#2342400
07/24/17 01:37 PM
07/24/17 01:37 PM
Posts: 625 Indianapolis In. usa
Quickrunner
Not to sound stupid but why other than some gazillion horsepower deal that needs towed back after a run is it now a "thing" to hit neutral at end of a run? I bracket raced a 9 second car for 20 years and never had to do this. Building a new car now and its getting a th400, I already have Ried case and bell mocked up in chassis and looking at shifters, and valve bodies, and wondering if I need this? Car is getting Gen3 hemi with small whipple or procharger blower and will be street/strip drag week type car. 1000 hp max looking to hit mid to high 8's. I'm thinking all I need is good reverse manual valve body with transbreak and a good a PPP shifter. Am I missing something? Are there applications at this level that need to click it off and hit Neutral after a pass?
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: "Clean neutral" Why?
[Re: Quickrunner]
#2342450
07/24/17 03:05 PM
07/24/17 03:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I wouldnt waste my time on one.. it isnt worth the cost to just get your rpms down at the end of a pass... I let the rpm slow the car
[Re: fbs63]
#2342508
07/24/17 04:23 PM
07/24/17 04:23 PM
Posts: 25,966 Rio Linda, CA
John_Kunkel
Rio Linda, CA
And for spark plug readings i.e. shift to Neutral at the end of the run and shut down the engine.
[Re: Quickrunner]
#2342568
07/24/17 05:49 PM
07/24/17 05:49 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
My Last hemi car had a significant drop in oil pressure after a full pass while hard on the brakes until some of the oil ran down and wasn't slammed to the front of the pan. I know there are ways to correct this with baffling, but why correct an issue just to run a motor during deceleration. There isn't much gain by running your motor during hard deceleration, and it can be hard on parts. Sure people have survived for years without shutting off the motor and using a clean neutral, but it is a better way to go. Personally if I was starting from scratch on a new build I would go clean neutral, if you already have the parts its probably not worth the expense to go the other way.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: Quickrunner]
#2342610
07/24/17 07:06 PM
07/24/17 07:06 PM
Posts: 4,210 New York
polyspheric
New York
Closing the throttle from trap speed is the absolute worst tension load the rods ever see. Passing over TDC at 29" of vacuum tries to pull the caps off, bend the pins, etc. Luckily your stall speed catches some of it.
Boffin Emeritus
[Re: Quickrunner]
#2342697
07/24/17 09:13 PM
07/24/17 09:13 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
forgive my ignorance here, but, if the engine isn't turning the pump, how is the transmission getting it's lubrication while the vehicle is moving?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: polyspheric]
#2342949
07/25/17 10:18 AM
07/25/17 10:18 AM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
Closing the throttle from trap speed is the absolute worst tension load the rods ever see. Passing over TDC at 29" of vacuum tries to pull the caps off, bend the pins, etc. Luckily your stall speed catches some of it. This. Your engine will thank you.
[Re: mopar873]
#2343103
07/25/17 03:35 PM
07/25/17 03:35 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
That thing sounds beautiful thank you.. it has been a fun project...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
