73 Road Runner 15x10" Back Spacing
#2342375
07/24/17 12:37 PM
07/24/17 12:37 PM
Posts: 173 PA
RoadRunner73
PA
Looking to buy some 15x10" for my 73 Road Runner... Can someone help me out and tell me the backspacing I'll need to shove it in and have it in the wheel well without have to jack the rear sky high? Was looking at the Torq Thrust II's ... https://www.summitracing.com/parts/are-vn5155165/recommendedparts
----- 1973 Plymouth Road Runner
Re: 73 Road Runner 15x10" Back Spacing
[Re: RoadRunner73]
#2342413
07/24/17 01:59 PM
07/24/17 01:59 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
I would recommend you measure (and/or see if you can borrow a couple of used wheels) to see what fits YOUR car..
Another persons post on here took recommendations that did not work..
I have seen recommendations for the car I have and there is NO WAY the wheels/tires recommended would ever fit...
[Re: floridian]
#2342565
07/24/17 05:43 PM
07/24/17 05:43 PM
Posts: 6,224 JERSEY
RJS
JERSEY
I have seen recommendations for the car I have and there is NO WAY the wheels/tires recommended would ever fit... Solid advice right there, but I can add this. On a 71-2 you can run a 15x10 with 5.5 BS and a 275-60-15 + tire with no modifications. Ron
