Re: oil pump drive
[Re: moparsquid]
#2342027
07/23/17 04:49 PM
07/23/17 04:49 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Do you have a billet cam? The bronze gear isn't needed if your cam is cast. Lift has nothing to do with it, it's the incompatibility of the billet cam with the iron pump gear.
Re: oil pump drive
[Re: John_Kunkel]
#2342553
07/24/17 05:27 PM
07/24/17 05:27 PM
Posts: 1,107 Spring Valley ,Ca.
moparsquid
Spring Valley ,Ca.
its a iron cam after a bit of research I got that conclusion thanks Do you have a billet cam? The bronze gear isn't needed if your cam is cast. Lift has nothing to do with it, it's the incompatibility of the billet cam with the iron pump gear.
