Re: Low Pedal
[Re: ct440rod]
#2341957
07/23/17 02:10 PM
07/23/17 02:10 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
yup
but won't hurt to bleed brakes all around to be sure.
and inspect lines, etc, to see where that fluid went/is leaking.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Low Pedal
[Re: ct440rod]
#2341978
07/23/17 02:55 PM
07/23/17 02:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Front reservoir feeds the REAR brakes.
Fix the leak.
Re: Low Pedal
[Re: Supercuda]
#2341989
07/23/17 03:19 PM
07/23/17 03:19 PM
amxautox
Fix the leak. And the rear shoes might be all worn away, so check that.
Tom
author unknown
Re: Low Pedal
[Re: ct440rod]
#2341995
07/23/17 03:33 PM
07/23/17 03:33 PM
Supercuda
About to go away
About to go away
up yours
Theoretically, the self adjuster should compensate for worn shoes, if it's not, fix it.
Re: Low Pedal
[Re: TJP]
#2342043
07/23/17 05:16 PM
07/23/17 05:16 PM
RapidRobert
As said, find/fix the leak in the rear brake half of the system (MC/wheel cyl/lines) then bleed the MC then bleed the rear drums.
