Low Pedal #2341955
07/23/17 02:06 PM
07/23/17 02:06 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
70 Challenger notice break pedal going further down then normal. adjusted break and same. Front part of master cylinder was out of fluid. Does that mean I only have to bleed front Breaks ? Stock break and master . .
thanks
'Gregg
Re: Low Pedal [Re: ct440rod] #2341957
07/23/17 02:10 PM
07/23/17 02:10 PM
On The Boat, On The Lake, Wa. ...
amxautox Online content
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Online Content
yup
but won't hurt to bleed brakes all around to be sure.
and inspect lines, etc, to see where that fluid went/is leaking.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Low Pedal [Re: ct440rod] #2341978
07/23/17 02:55 PM
07/23/17 02:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Front reservoir feeds the REAR brakes.
Fix the leak.
Don't be the exception.
Re: Low Pedal [Re: ct440rod] #2341979
07/23/17 02:55 PM
07/23/17 02:55 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
If you can't find an obvious leak, check the MC/booster.. I have seen the booster suck brake fluid.....
Re: Low Pedal [Re: Supercuda] #2341989
07/23/17 03:19 PM
07/23/17 03:19 PM
Fix the leak.
And the rear shoes might be all worn away, so check that.
Tom
author unknown
Re: Low Pedal [Re: ct440rod] #2341995
07/23/17 03:33 PM
07/23/17 03:33 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Theoretically, the self adjuster should compensate for worn shoes, if it's not, fix it.
Re: Low Pedal [Re: Supercuda] #2342003
07/23/17 03:58 PM
07/23/17 03:58 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I'll guess rear cylinders are leaking whistling twocents
Re: Low Pedal [Re: TJP] #2342043
07/23/17 05:16 PM
07/23/17 05:16 PM
As said, find/fix the leak in the rear brake half of the system (MC/wheel cyl/lines) then bleed the MC then bleed the rear drums.
Re: Low Pedal [Re: ct440rod] #2342077
07/23/17 07:18 PM
07/23/17 07:18 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Just have 100 miles on it from a 15 year restore. Don't see any leaks guess have to pull the back drums off.
Re: Low Pedal [Re: ct440rod] #2342202
07/23/17 11:49 PM
07/23/17 11:49 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
It may be possible that whomever bled the brakes failed to fill the reservoir after doing so. shruggy A quick drum pull will confirm if you have leaky cylinders, beer popcorn
