Re: FiTech , No ported vacuum problem
[Re: BDW]
#2341536
07/22/17 04:42 PM
07/22/17 04:42 PM
Posts: 25,969 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Why would running the advance off manifold vacuum cause hard starts? You still only have the initial 15° while cranking.
[Re: BDW]
#2341553
07/22/17 05:28 PM
07/22/17 05:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You might find your problem isn't starting, but trying to maintain a stable idle speed.
[Re: BDW]
#2341713
07/22/17 10:49 PM
07/22/17 10:49 PM
Posts: 3,907 Oregon
hooziewhatsit
Ported vacuum should show up just after the throttle blades are opened. If it's not showing up until higher throttle openings, it could be related. I'm assuming your timing is being ran by the distributor/vac advance, and not the Fitech unit? As long as your idle vacuum (in D if automatic) is a few points above where the vac advance drops out, you can run it off manifold just fine. ie, idles in gear at 13", make sure the can is 'all in' by 10ish. You just don't want it to idle near where the can starts to move, otherwise it will really start to hunt as the can backs off, which changes the timing, which changes the idle speed, which changes the vacuum, which changes the timing ![panic panic](/ubbthreads/images/graemlins/custom/panic.gif)
[Re: BDW]
#2341718
07/22/17 10:54 PM
07/22/17 10:54 PM
Supercuda
About to go away
About to go away
up yours
The tipping point on the vacuum advance can is adjustable on stock distributors.
[Re: BDW]
#2341732
07/22/17 11:21 PM
07/22/17 11:21 PM
Posts: 3,907 Oregon
hooziewhatsit
At high load (very low vacuum), the vac advance drops out. So, under load when you floor it, it goes away and you're left with the initial + mechanical, limiting total advance to 30ish degrees to avoid pinging.
At idle and cruising, you should have 10"+ of vacuum, so the vac advance is adding to the initial + mechanical, just like ported does. Giving you 45ish total, cleaning up the burn and improving MPG.
Ported just has zero vacuum at idle, but otherwise works the same when you're above idle.
[Re: BDW]
#2341750
07/23/17 12:00 AM
07/23/17 12:00 AM
RapidRobert
FiTechs only solution is to use manifold vacuum, sounded like a known problem. With my initial set to 15, won't this cause hard starts? if you set the initial to 15 on manifold when running I could see that it automatically being way retarded from that when starting (from no vac adv) could cause very hard starting. Maybe there is enough cranking vacuum to activate it, I never thought about that. You might Google it or call FiTech or Don at FBO (he is a manifold afficionado) As they've for sure dealt with this. holler how it goes.
[Re: BDW]
#2342021
07/23/17 04:37 PM
07/23/17 04:37 PM
John_Kunkel
Rio Linda, CA
Always read you never want to run manifold vacuum for the advance. Lot's of folks advocate using manifold vacuum. All my cars run noticeably better with manifold vacuum including my FI Tech car.
[Re: BDW]
#2342178
07/23/17 10:58 PM
07/23/17 10:58 PM
RapidRobert
After I connected the manifold vacuum, it idled rough and had a serious backfire with I blipped the throttle. what was the initial when you connected it to manifold and is the rotor phasing OK?
