Standard size carb stud? #2341491
07/22/17 02:59 PM
07/22/17 02:59 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
I am at work now and want to order online a longer carb stud and wing nut. Truck has 360 with edlebrock 4 barrel carb and aftermarket air cleaner. I'm putting back the factory air cleaner and need longer stud. Is there a standard size? I can't tell the size by looking, am stuck at work and don't have much time off lately and really want to order it now. Is this right for an edlebrock carb "1/4-20"? I figure they all must be the same.
Thank. Anxious to get it ordered and don't feel like dealing auto parts stores even if I get the time to get there in next few days.
Facts are stubborn things.
Re: Standard size carb stud? [Re: larrymopar360] #2341504
07/22/17 03:31 PM
07/22/17 03:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
1/4-20 is correct. If you have a home depot or similar store nearby just pick up a length of 1/4-20 all thread and cut it to length. beer
Re: Standard size carb stud? [Re: TJP] #2341510
07/22/17 03:57 PM
07/22/17 03:57 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
If you use all-thread be sure to use a jam nut so the stud doesn't back out. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Standard size carb stud? [Re: I_bleed_MOPAR] #2341533
07/22/17 04:35 PM
07/22/17 04:35 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Original studs were 1/4 20 US intake and 1/4 28 NF nut end if it matters.
Re: Standard size carb stud? [Re: larrymopar360] #2341682
07/22/17 10:09 PM
07/22/17 10:09 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Ok, thanks all. I just can't even make it to Home Depot right now with the way work is and see one online for five bucks including shipping!
Thanks again!
