Re: Why dont my tires fit? Wrong size? [Re: 69CudaFan] #2340070
07/19/17 11:39 PM
07/19/17 11:39 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Only way I could get 275/60/15 under my 71 Barracuda was with modified steel rims, I cut the centres out and fitted them to 8" bands, cant rember exactly but it was very close to 5" back space.
My son and I now do custom rims for cash on the side.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Why dont my tires fit? Wrong size? [Re: dogdays] #2341462
07/22/17 01:52 PM
07/22/17 01:52 PM
Sandy Eggo, CA
69CudaFan Offline OP
Sandy Eggo, CA
So based upon my clearances, the plan is a 68-70 B Body dimension Dana 60, ESPO +1 6 leaf HD springs, and Bilstein RCD Shocks. Should tighten everything up back there, get the ride height much better, and tuck things under the wheelwells a little better with clearance to spare. I also am aware of the need for new plates and U bolts, and hard lines. Any other considerations?
I noticed a little sag on the passenger side versus the driver's side which tells me those stockers are a little tired.
I verified drum to drum was about 61.5 inches (stock 7 1/4 from what I can tell. Ride height on the passneger side is about 3/4 inch lower than the driver side. No interest in a re-arch because the plan is a 440 and 18 spline setup to a Dana 60 anyway.
Re: Why dont my tires fit? Wrong size? [Re: 69CudaFan] #2343187
07/25/17 06:02 PM
07/25/17 06:02 PM
dogdays Offline
dogdays  Offline
I'd be looking for level with you in drivers seat.
I still think you should build a Dana 60.
R.
