451 ICH 440-1 383 based combination - input needed
#2341249
07/21/17 11:35 PM
07/21/17 11:35 PM
Posts: 524 Mesa, AZ
Bill_T
Mesa, AZ
After a survey of the parts on hand, here is one possible combination:
383 block .040 over Hughes girdle factory caps (all machined). Eagle 3.9 inch crank 383 mains 2.2 Rod journals. K1 6.7 inch H beams (from DRAM - RIP). Diamond 4.29 inch pistons. 1.32 CD 4cc valve reliefs. Rotating assembly balanced. Indy 440-1 milled 62 cc chambers - flow approx 340cfm: These are circa Y2K vintage. ICH 1.6 ratio blue Dove rockers - almost new. 400-2 Indy intake (supposedly ported by Indy) Summit balancer. Holley 850 (8082 with adapter can be added later). Milodon single line static, Melling HV pump Cam (to be purchased) – Howards 722422-08: Lift: .66 / .68 (w/1.6), Duration @ .050: 264/272 Centerline: 104? Lifters Howards EDM Valve Springs (to be purcahsed)? K-motion K850?
Compression around 12.7 to one.
Goals: put some parts into service. Bring car (3300 lbs, ladder bar and 727) in garage since 2004 back to life. Make a few passes at the strip and drive 20 miles on the street at least one time.
Thoughts on the cam and valve springs? Other?
This space not for rent.
Re: 451 ICH 440-1 383 based combination - input needed
[Re: Bill_T]
#2341444
07/22/17 01:07 PM
07/22/17 01:07 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'm not a big fan of the fast rate cams and 1.6 rockers.
The motor will likely be fairly high rpm oriented, which will require plenty of spring to maintain control of the valvetrain.
Probably want 54-5600 stall and a 7000-ish shift point.
[Re: fast68plymouth]
#2341506
07/22/17 03:42 PM
07/22/17 03:42 PM
Posts: 524 Mesa, AZ
Bill_T
Mesa, AZ
Thanks all for the responses. I recognize the combination is not ideal, and the short block was originally collected for a different set of heads. The -1 set has history for me so selling is probably not an option.
Fast - if I was to have you spec a cam for the combo (such as it is), about how long does it take to get usually?
