Page 2 of 3 1 2 3
Re: 511 Alive and well once again. [Re: Wookie316] #2341212
07/21/17 10:42 PM
07/21/17 10:42 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Originally Posted By Wookie316
I know anything in an A body can be a pain. Helped an bud put a 400 in his Duster last year. Inner fenders were removed and it was still a pain.
yes it is, ask me how I know. LOL
Re: 511 Alive and well once again. [Re: Wookie316] #2341223
07/21/17 10:59 PM
07/21/17 10:59 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Thanks. Finding ambition to pull a perfectly good 440 out is my hurdle right now.
That dyno sheet should give you plenty of ambition up wrench
Re: 511 Alive and well once again. [Re: Wookie316] #2341339
07/22/17 02:53 AM
07/22/17 02:53 AM
Alberta
Wookie316 Offline OP
Alberta
Yeah probably get started Sunday night. Has to be running Wednesday so I can load Thursday. Weather forecast changed though and not looking great for next Friday.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: 511 Alive and well once again. [Re: Wookie316] #2341567
07/22/17 05:59 PM
07/22/17 05:59 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
If you cant find the ambition, could I use the 511, just to test it for you
Re: 511 Alive and well once again. [Re: 10secGTX] #2341586
07/22/17 06:44 PM
07/22/17 06:44 PM
Alberta
Alberta
I am sure many would line up to test.
Re: 511 Alive and well once again. [Re: Wookie316] #2341675
07/22/17 10:03 PM
07/22/17 10:03 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Sounds like she will push your Charger down the track very fast. Gotta love the bigblock wedge Mopars ! Good luck with it. up Ron
Re: 511 Alive and well once again. [Re: Wookie316] #2343150
07/25/17 04:53 PM
07/25/17 04:53 PM
Alberta
Alberta
It is sitting in car. Should be all back together no later than tomorrow night. All ready for Friday night test and tune.
Re: 511 Alive and well once again. [Re: Wookie316] #2343277
07/25/17 09:29 PM
07/25/17 09:29 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Wookie !
Show us a pic of the progress !!
What headers are you using ?
Dan
67 Barracuda...at rest without an engine..
Re: 511 Alive and well once again. [Re: Wookie316] #2343506
07/26/17 04:31 AM
07/26/17 04:31 AM
Alberta
Alberta
Photobucket wants $ from me and it isn't happening. Any other ways to post a photo?
Got it running tonight. Get the hood on tomorrow and check things over. Should be ready to test Friday.
Re: 511 Alive and well once again. [Re: Wookie316] #2343874
07/26/17 08:08 PM
07/26/17 08:08 PM
dogdays Offline
dogdays  Offline
How to attach a picture has been posted many times. After you finish your post, click on File Manager below the post. It opens a new window and asks you what picture you'd like to attach. I use the "Browse" button and find it on my computer. Open the pix on my computer, it appears in the new window. Hit Add Picture. If you have another picture go back to Browse and get it. When you're done, hit Done Adding Pictures
Re: 511 Alive and well once again. [Re: Wookie316] #2343925
07/26/17 09:49 PM
07/26/17 09:49 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
picture test
Re: 511 Alive and well once again. [Re: dogdays] #2343928
07/26/17 09:49 PM
07/26/17 09:49 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Thanks, as you can see it worked, Thanks again smile
Re: 511 Alive and well once again. [Re: Wookie316] #2344267
07/27/17 12:53 PM
07/27/17 12:53 PM
Alberta
Alberta
511 running in car
Here is a video.
Re: 511 Alive and well once again. [Re: Wookie316] #2344292
07/27/17 01:25 PM
07/27/17 01:25 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Sounds angry!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 511 Alive and well once again. [Re: Wookie316] #2344529
07/27/17 10:18 PM
07/27/17 10:18 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Hope mine sounds that good.
Re: 511 Alive and well once again. [Re: Wookie316] #2345110
07/29/17 03:32 AM
07/29/17 03:32 AM
Alberta
Alberta
Ran 10.21 @ 133 with a 1.45 60 foot. All smiles here.
Re: 511 Alive and well once again. [Re: Wookie316] #2345114
07/29/17 04:31 AM
07/29/17 04:31 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Well done
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 511 Alive and well once again. [Re: Wookie316] #2345222
07/29/17 01:00 PM
07/29/17 01:00 PM
Alberta
Alberta
Re: 511 Alive and well once again. [Re: Wookie316] #2345251
07/29/17 01:34 PM
07/29/17 01:34 PM
What RPM are you shifting it at?
It sounds like it likes to rev, mine did boogie work
Re: 511 Alive and well once again. [Re: Wookie316] #2345257
07/29/17 01:39 PM
07/29/17 01:39 PM
Alberta
Alberta
That was 7000. It likes RPM. Not stumbles or hiccups at all. 60 is down a bit from spray which I expected. Maybe an adjustment will help not sure? Have tach video I'm going to send Lenny and see what he thinks?
Page 2 of 3 1 2 3
