Source for repro wiring harnesses? #2340696
07/21/17 12:01 AM
07/21/17 12:01 AM
Wisconsin USA
themoparmanjc Offline OP
Wisconsin USA
Anyone know of anybody reproducing wiring harnesses for our trucks? I could just buy a wiring diagram and repair what's there but it would be nice to be able to replace all of it. I really don't want aftermarket wiring either such as the painless system. Used oem harnesses in good shape are almost impossible to find.
Don’t Buy From Famous Bob AKA Bob McCarty in Oklahoma. He is a Crook!
Re: Source for repro wiring harnesses? [Re: themoparmanjc] #2340734
07/21/17 12:49 AM
07/21/17 12:49 AM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
for what year truck?
Re: Source for repro wiring harnesses? [Re: themoparmanjc] #2340836
07/21/17 09:56 AM
07/21/17 09:56 AM
Wisconsin USA
Wisconsin USA
85
Re: Source for repro wiring harnesses? [Re: themoparmanjc] #2343001
07/25/17 12:19 PM
07/25/17 12:19 PM
scratchnfotraction Offline
I gave up on finding a 85D150 harness and went with a complete harness from an 86W150
FYI..86 was a change in plug styles so you need 82-85 I found this after I removed my 85 harness and installed the underhood/dash harness from the 86...85 chassis/tail light harness would not plug up to 86 harness.
took a while to locate a 86 chassis harness out of Alabama JY. and the correct plug-in front turn sig pig tails for 86 out of Kansas JY.
I suggest repair to what you have depending on condition.
Re: Source for repro wiring harnesses? [Re: themoparmanjc] #2345809
07/30/17 06:07 PM
07/30/17 06:07 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
There's some used harnesses for '85 on ebay at $60. No sure if it'd be worth it to you but if you search "85 dodge truck wire harness" you'll see it. I wish LMC truck had some repro's.
I know this really wasn't your question but I thought I'd mention it anyway. Good luck.
Facts are stubborn things.
Re: Source for repro wiring harnesses? [Re: larrymopar360] #2346229
07/31/17 03:16 PM
07/31/17 03:16 PM
Wisconsin USA
Wisconsin USA
Hey thanks for the heads up bud. Anything has to be better than what I already have. Between the Texas heat cracking the coating of the wires and a backyard mechanic hacking up the harnesses, I'm willing to buy a used one at this point
Re: Source for repro wiring harnesses? [Re: themoparmanjc] #2346230
07/31/17 03:24 PM
07/31/17 03:24 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Which harness? Under hood headlight harness, engine harness, dash, rear light?
Re: Source for repro wiring harnesses? [Re: Hugh Jorgan] #2346622
08/01/17 11:53 AM
08/01/17 11:53 AM
Wisconsin USA
Wisconsin USA
Under hood and rear lights
