Re: When were air bags first installed in trucks?
[Re: QuickDodge]
#2340491
07/20/17 07:06 PM
07/20/17 07:06 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
1994 and they were standard. Just the drivers side first. I forget when passenger air bags started, 1998 or 2000, somewhere around there.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2340768
07/21/17 01:45 AM
07/21/17 01:45 AM
Posts: 240 fredericksburg virginia
mopwrd340
1994 and they were standard. Just the drivers side first. I forget when passenger air bags started, 1998 or 2000, somewhere around there. What he said.
[Re: 135sohc]
#2341268
07/21/17 11:56 PM
07/21/17 11:56 PM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
Only moparts gets the posting responces so garbled up This was intended as a quote add on to the responce above it. Passenger side airbags came into effect. 1998 for the 1500-3500 trucks 1997 for the Dakota 1998 for the B vans
[Re: poorboy]
#2341386
07/22/17 10:31 AM
07/22/17 10:31 AM
Guitar Jones
My 93 Dakota has a driver side air bag, least that's what the cover says. Gene Yes, the Dakota got a DAB in 93. I was speaking of the full size truck since the OP didn't specify B van or Dakota. And thanks 135sohc for the PAB clarification.
[Re: volaredon]
#2341809
07/23/17 02:36 AM
07/23/17 02:36 AM
Posts: 993 Mid Michigan
Mr. Smurf
Mid Michigan
my 93 Dakota didn't have one.... even before I wrecked it.... but my 94 did. Have a 92 now (doesn't have one) and a 96 (that one does have one) neither have pass side airbag. My 93 Dakota had one.... Ed
[Re: QuickDodge]
#2342213
07/24/17 12:10 AM
07/24/17 12:10 AM
Posts: 1,151 Cruising!
QuickDodge
Cruising!
Sorry about the confusion! I was interested in air bag info on the full size trucks.
I read on another website that the air bag was introduced in 1994, just like Guitar Jones mentioned. It seems like I saw a drivers side air bag in a late square body rams. 1992 or 1993 perhaps???? Is my memory just incorrect? Was the air bag available as an option before 1994?
[Re: QuickDodge]
#2342286
07/24/17 06:49 AM
07/24/17 06:49 AM
Guitar Jones
I read on another website that the air bag was introduced in 1994, just like Guitar Jones mentioned. It seems like I saw a drivers side air bag in a late square body rams. 1992 or 1993 perhaps???? Is my memory just incorrect? Was the air bag available as an option before 1994? No, air bags are not and never were an option. No full size truck got an air bag until the redesign in 94. Now could you put the newer column and or steering wheel in the 93 and prior? Yeah you can but there is way too much stuff to actually make the air bag functional.
