Spray from the line ? #234024
02/23/09 06:16 PM
02/23/09 06:16 PM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Hi guys... what would be better for 1/8 ET!?
Spray a 100hp shot from the line or
spray a 180-200hp shot past 4000rpm ?!
the engine will rev 6800rpm.
Re: Spray from the line ? [Re: dart_73_br] #234025
02/23/09 07:11 PM
02/23/09 07:11 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Will it hook?
Re: Spray from the line ? [Re: dart_73_br] #234026
02/23/09 07:19 PM
02/23/09 07:19 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Let 'er buck. 250 when the light goes green.
Re: Spray from the line ? [Re: Lil Demon] #234027
02/23/09 07:19 PM
02/23/09 07:19 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
use a progressive controller, leave on 100 and ramp in the rest as you go.
Re: Spray from the line ? [Re: Lil Demon] #234028
02/23/09 07:37 PM
02/23/09 07:37 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
Will it hook?
Yeah, assuming it hooks! (I hope.. finishing my mini-tubbing, ladder bars + 12" street tires)
By the way... it will be a forged pistons + forged rods + arp main bolts + stock crank....
Do you think a 100 shot off the line could hurt the engine !?
Re: Spray from the line ? [Re: dart_73_br] #234029
02/23/09 07:40 PM
02/23/09 07:40 PM
Renton Washington
Triple Threat Offline
Renton Washington
Will it hook?
No, Many many people spray a lot more than 100 of the line. You will be fine.
Remember hitting the sauce off the line is going to give the motor more power and thus make the converter flash a bunch higher than it will without the juice. If you plan on using it alot, you need to get a converter that is built for it, or bad things can happen.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Spray from the line ? [Re: dart_73_br] #234030
02/23/09 07:41 PM
02/23/09 07:41 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
With a 2000 stall yes. 3500 and up, no. IMO thats a starter shot, nothing to be worried about.
Re: Spray from the line ? [Re: dart_73_br] #234031
02/23/09 08:03 PM
02/23/09 08:03 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Give more details of the car/weight/current motor HP range and current performance numbers, the exact tire brand, converter, trans, rear gear. Transbrake or footbrake? Lastly, how is the track surface you race on?
If things are right it'll take every bit of what you're wanting to throw at it (180-200) off the line. What system are you using? I'm sure ole Monte Smith can fix you right up if you don't have one currently. Good luck.
Re: Spray from the line ? [Re: EvilB1Dart] #234032
02/23/09 08:41 PM
02/23/09 08:41 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
As you wish...
Engine setup:
- 318 SB
- 2.02/1.60 ported J heads
- KB forged pistons (~11 CR)
- Scat H-Beam connection rods
- ARP main and Head studs
- 1.6 roller rockers
- Comp Cams XE284H cam 240/246 @.050
- Edelbrock Torker 2 with injector bungs
- EFI Megasquirt with 8 injectors
- Innovate LM-1 wideband O2 sensor
- 3.73 gears + ladder bars
- mini tubbed
- 295/50/15 Toyo tires
- 3400#lbs Dart
- manual transmission with ceramic clutch
Track is not that good....
The engine will run on ethanol. Wishing to make 400~450 hp + a 200~250 shot.
I´ve got a NOS 8 fogger Sportsman nitrous kit but also has a plate.
Re: Spray from the line ? [Re: dart_73_br] #234033
02/23/09 10:26 PM
02/23/09 10:26 PM
Ma
Voluster Offline
Voluster  Offline
Ma
The manual trans will be the most tricky part ni getting it to hook.
but other then that let it eat
Re: Spray from the line ? [Re: Voluster] #234034
02/23/09 10:32 PM
02/23/09 10:32 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
i let go off my transbrake, there is a .10 delay to a plate jetted .070/.067
then after .65 a progressive ramps in a fogger jetted .032/.028 The progressive starts at 70% and goes to 100% in one second
I have been 5.30's in the 1/8 at 130 on a 295 drag radial
....BAD A$$ STREET CAR.....
Re: Spray from the line ? [Re: n20mstr] #234035
02/24/09 10:43 AM
02/24/09 10:43 AM
I beleive in using whatcha got. SO, if you have the sauce, use it. I always had mine on a micro switch, and it activated under full throttle. With my stick car, I left @ 7500 RPM, and it would go:
Trip the pre-stage lights, bring revs up to 5000 RPMs.
Roll into the lights, deck it, that way it is spraying before you are off the clutch, and when you side step the clutch on the spray, it is all good
Same goes for auto:
Roll into pre-stage, foot brake, bring revs up (depnding on your stall)
Trip the lights, set the trans brake, deck it, and now you are spraying the converter, and your 60' will dwindle down.
Re: Spray from the line ? #234036
02/24/09 10:55 AM
02/24/09 10:55 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Same goes for auto:
I think both of those scenarios are a good recipe for blowing the hood off lol.
68 Barracuda Formula S 340
Re: Spray from the line ? #234037
02/24/09 11:06 AM
02/24/09 11:06 AM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
5000 RPM with a 318 leaving on oxide??? put the pipe down!!!
Re: Spray from the line ? [Re: dthemi] #234038
02/24/09 11:09 AM
02/24/09 11:09 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
w/DT Use a progressive controller. Bring it in a little at a time, until the tires break loose, then back it off.
Yeah, it's got a smallblock.
Re: Spray from the line ? [Re: 340B5] #234039
02/24/09 11:13 AM
02/24/09 11:13 AM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
I cant imagine a mini tubbed car with a 318, is gonna put away the tires with a 250 shot even... My car will hook on the street leavin on 225 with a 496... just sayin... maybe the tracks covered with gravel?
Re: Spray from the line ? [Re: BB70DUSTER] #234040
02/24/09 11:14 AM
02/24/09 11:14 AM
I was refering to MY car....sorry, not your 318"
Re: Spray from the line ? [Re: Bad340fish] #234041
02/24/09 11:16 AM
02/24/09 11:16 AM
Same goes for auto:
Unless you know what you are doing: which since I never had a backfire one, and after 4+ seasons, and an easy 300+ passes of doing so, I think I qualify as knowing what I am doing
Re: Spray from the line ? #234042
02/24/09 11:39 AM
02/24/09 11:39 AM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
No 318 under my hood buddy...
Re: Spray from the line ? [Re: BB70DUSTER] #234043
02/24/09 04:45 PM
02/24/09 04:45 PM
so cal
cmcgee123 Offline
cmcgee123  Offline
so cal
i leave on a 200 hit. no problems at all.
nitrous is like a really hot chick with an std you want to hit it but youre affraid of the outcome.
