Re: Spray from the line ?
[Re: Lil Demon]
#234028
02/23/09 07:37 PM
02/23/09 07:37 PM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
Will it hook?
Yeah, assuming it hooks! (I hope.. finishing my mini-tubbing, ladder bars + 12" street tires)
By the way... it will be a forged pistons + forged rods + arp main bolts + stock crank....
Do you think a 100 shot off the line could hurt the engine !?
[Re: dart_73_br]
#234031
02/23/09 08:03 PM
02/23/09 08:03 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Hi guys... what would be better for 1/8 ET!?
Spray a 100hp shot from the line or spray a 180-200hp shot past 4000rpm ?!
the engine will rev 6800rpm.
Give more details of the car/weight/current motor HP range and current performance numbers, the exact tire brand, converter, trans, rear gear. Transbrake or footbrake? Lastly, how is the track surface you race on?
If things are right it'll take every bit of what you're wanting to throw at it (180-200) off the line. What system are you using? I'm sure ole Monte Smith can fix you right up if you don't have one currently. Good luck.
[Re: EvilB1Dart]
#234032
02/23/09 08:41 PM
02/23/09 08:41 PM
dart_73_br
Sao Paulo, Brazil
As you wish...
Engine setup: - 318 SB - 2.02/1.60 ported J heads - KB forged pistons (~11 CR) - Scat H-Beam connection rods - ARP main and Head studs - 1.6 roller rockers - Comp Cams XE284H cam 240/246 @.050 - Edelbrock Torker 2 with injector bungs - EFI Megasquirt with 8 injectors - Innovate LM-1 wideband O2 sensor - 3.73 gears + ladder bars - mini tubbed - 295/50/15 Toyo tires - 3400#lbs Dart - manual transmission with ceramic clutch
Track is not that good....
The engine will run on ethanol. Wishing to make 400~450 hp + a 200~250 shot.
I´ve got a NOS 8 fogger Sportsman nitrous kit but also has a plate.
[Re: Voluster]
#234034
02/23/09 10:32 PM
02/23/09 10:32 PM
Posts: 4,690 On the parachute mount
n20mstr
i let go off my transbrake, there is a .10 delay to a plate jetted .070/.067 then after .65 a progressive ramps in a fogger jetted .032/.028 The progressive starts at 70% and goes to 100% in one second
I have been 5.30's in the 1/8 at 130 on a 295 drag radial
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#234035
02/24/09 10:43 AM
02/24/09 10:43 AM
I beleive in using whatcha got. SO, if you have the sauce, use it. I always had mine on a micro switch, and it activated under full throttle. With my stick car, I left @ 7500 RPM, and it would go: Trip the pre-stage lights, bring revs up to 5000 RPMs. Roll into the lights, deck it, that way it is spraying before you are off the clutch, and when you side step the clutch on the spray, it is all good Same goes for auto: Roll into pre-stage, foot brake, bring revs up (depnding on your stall) Trip the lights, set the trans brake, deck it, and now you are spraying the converter, and your 60' will dwindle down.
#234036
02/24/09 10:55 AM
02/24/09 10:55 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I think both of those scenarios are a good recipe for blowing the hood off lol.
68 Barracuda Formula S 340
#234037
02/24/09 11:06 AM
02/24/09 11:06 AM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
5000 RPM with a 318 leaving on oxide??? put the pipe down!!!
[Re: BB70DUSTER]
#234040
02/24/09 11:14 AM
02/24/09 11:14 AM
I was refering to MY car....sorry, not your 318"
[Re: Bad340fish]
#234041
02/24/09 11:16 AM
02/24/09 11:16 AM
Unless you know what you are doing: which since I never had a backfire one, and after 4+ seasons, and an easy 300+ passes of doing so, I think I qualify as knowing what I am doing
#234042
02/24/09 11:39 AM
02/24/09 11:39 AM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
No 318 under my hood buddy...
